It is impossible to 'Forget' a code you are using 20 times a day!
https://www.google.com/search?q=nokia+X2+hard+reset
SOURCE: i forgot my security code of nokia 7310 supernova
HI,
You have to type in security code of your phone in order to log into the phone....
By default the security code is 12345 and if you have changed it, you must be knowing....
BUT IF YOU WERE NOT ABLE TO GET INTO THE MOBILE WITH THE 12345 OR IF YOU FORGET THE SECURITYCODE, the one and the only way is to flash the mobile phone(ie, reinstalling the firmware), this cant be done by the normal person, u have to take the phone to nearest service center and flash it, they may charge u very minimal amount......
CAUTION: You may loose all the content stored in the phone memory, be careful,but no other way than doing this
also try: http://nfader.z-host.ru/
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
SOURCE: i forgot my phone security code of nokia 3315 cell
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
SOURCE: nokia 5130c-2 forgot security code
hi
visit on this site http://www.unlockme.co.uk/master.php
after visiting on that site you have to enter your phone's imei no. in the textbox which are given on that page
after entering your imei no. click on get master code button to get your phone's master code
SOURCE: forgot my security code for nokia 1209,the IMEIno:358287031050082
Phone IMEI: 358287031050082
Calculating Codes...
MASTER CODE : 3430107356
Codes Calculated OK...
Done..
