There are two reasons normally that the cassette door won't open when you slide the Eject button on the JVC GR-SXM320. One: the camera uses a powered eject feature. If the battery is low and the AC adapter isn't plugged in and powering the camera, this doesn't work. Two: if the LCD monitor screen is not open to more than a 60 degree angle, then there is an interlock that keeps the cassette door closed. This avoids the door hitting the screen. It's best to have the monitor at a 90 degree angle to the camera body when you open the cassette. Press Stop if there is a chance that the camera is recording to the current cassette.
JVC has the manual here: http://resources.jvc.com/Resources/00/00/97/LYT0465-001A.pdf .
Note: since the camera is older, check that the AC adapter is getting warm when it's plugged in and connected to the camera. This checks if the adapter is working. Check if your battery pack is good. If you have the BN-V856U battery pack, you need the AA-V80U charger to charge the battery. The charger that came with the camera will not work.
Third party battery packs and chargers are still available for the GR-SXM320. Use the manual to look up the part number and Google for the battery or use the camera model number to find available parts. For example, a replacement BN-V11U battery is available at Amazon and here: https://www.bestbatt.com/JVC-BN-V11U-BN-V12U-BN-V14U-BNV-V18U-Battery-p/bbbnv11u.htm .
I hope this helps.
SOURCE: how do I close the cassett holder? (JVC GR-D70 comcorder)?
man just try pushing that place by a small support on its lower side. ( imean below... just the opposite side where it is told to "push here". i hope if you didnt broke its locking mechanism, it will work..
SOURCE: JVC GR-D728 CAMCORDER
http://www.jvc.co.uk/template.php?page=100102
This is the same text as above but extends the repair perid to Dec. 08.
SOURCE: Cassette door is not closing
Your loading motor is no longer working or your mechanism is out of alignment.
SOURCE: GR-D250U manuel
You can get it here:
http://camera.manualsonline.com/ex/thread/view/idThread/124172
Please note that you will have to register with them for free to download the manual.
Hope that helped!
Please assign a Fixya rating if this solution helped you!
SOURCE: jvc rv-b99 cassette door jammed
You need to take the unit apart. If you pull hard to open the door, you`ll break the plastic connector that moves the head up and down.
