Question about Salter Health & Beauty
Wet0 Can't get err off salter scale model 1250
6ya staff
SOURCE:
Anonymous
SOURCE: Can't open battery case
The middle part slides out. You'll need a small knife or a screwdriver to pry it out gently.
There are openings on two sides. One side has a larger opening than the other. Make sure you pry it out of the lager opening.
Once you gently slide it out, you'll see the two batteries. Make sure the positive side is facing up when you put them back in.
Hope that helps!
Posted on Aug 18, 2009
Anonymous
SOURCE: HealthSmart bathroom scale displays "Err"
Put scale in round file can. Buy another cheap scale.
Posted on Oct 05, 2009
Testimonial: "The new scale works great and was on sale at Wal-mart for only $29."
Anonymous
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
Joe Hogan
  • 10865 Answers
SOURCE: I own the Salter Stainless steel electronic
yes. here is the link to the company http://salter-scales.com/ just click on the link and then enter your country. then you will see a place for parts or to contact them.
Posted on Mar 25, 2010
Testimonial: "Thank you! Wow, didn't expect a reply so quickly. Appreciate your help."
Joe Hogan
  • 10865 Answers
SOURCE: Salter 9001 bathroom scale stopped working
Hi Pete. I don't keep receipts either : ^ )
No that I am done commeserating, try this. Remove the batteries. Use the eraser end of a common pencil to scrub and clean the battery contacts inside the battery compartment. Also pull the contacts a little closer to the surface if you can. Then reinstall the batteries and you may be up and running.
Please rate my answer as verey helpful thanks. Joe
Posted on Mar 26, 2010
How do i get battery compartment open on Salter kitchen scale model 2006
I went to the Salter website and I could not find that model number.
Salter Disc Electronic Digital Kitchen Scales White
However, looking at the other models they had there should be a door on the bottom of the scale. It looks like a release tab that you push in then lift up on. Give that a try.
Nov 22, 2017 | Salter Health & Beauty
My Salter model 3003 kitchen scale shows Err when I turn it on. How can I fix this?
This means that it cannot calibrate itself because the sensor is out of range. This can happen if you drop it or overload it. Check the feet on each of the for corners and make sure they are not stuck, you can do this with the unit on and see if it registers any force on the pads when you press and release them or use a screw driver to lift them SLIGHTLY. There are a lot of youtube videos on how to check and repair them.
Jul 30, 2016 | Salter 3003 Aquatronic Glass Electronic...
After changing battery, why does err appear and not a 0?
The replacement battery could be defective or installed incorrectly.
Sep 05, 2015 | Salter 9037 - Digital Bathroom Scales /...
Battery code for Salter kitchen scale Model 6055
i needs manuals of calibration of the scale salter model 6055
Aug 23, 2011 | Salter 2001 electronic kitchen scale
My Salter bathroom scales (model 929) are showing an ERR message. They seem to think everything weighs more than it does as if u press gently on them the weight goes up really quickly until limit reached...
The best day chessboard type is the traditional type of weight, in contrast, electronic weight scale error degreehighestelectronic
tems, affected by environments, bumps can make reading deviation.The use of electronic weight meter can more precisely?
Electronic scales are generally placed in the hard flat floor use, not on the carpet or other soft object surface by using.Each weight to body weight in the same place, the same time, wear the same clothes.
Hello, I just see a online stores
http://www.tmart.com/Digital-Scales/ sell digital scales. Some advice, for reference purposes only and finally I wish you luck!
Jul 25, 2011 | Salter Health & Beauty
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Sep 18, 2009 | Salter 2001 electronic kitchen scale
Health & Beauty Logo
Top Salter Health & Beauty Experts
Simon Ruddy
Simon Ruddy
Level 1 Expert
WordGoddess
Level 1 Expert
Terry
Terry
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
