I release the fitness machine Kettler Track Motion and after 3 seconds it stops and the error is 91
SOURCE: error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
SOURCE: What does error code Lr mean and how do I fix it?
http://www.bobvila.com/wwwboard/messages/155863.html
says:
just an FYI to anyone who might need to know. my neptune started kicking up an error of LR and stopping. i ended up sending an email to maytag and got a response back from one of their techs. the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced (P/N 12002039).
hope the info helps someone as i had a heck of a time finding it.
SOURCE: MY TREADMILL STOPS JUST A MINUTE AFTER STARTING.
Try Lubricating the belt with silicone spray.
Probably the resistence from the belt scraping over the ground board is too high, forcing the machine to switch off in order to prevent damage.
SOURCE: LF Error
"LF" is a Long Fill error. If the fill time exceeds roughly 10 minutes, the fill valves are shut down and the error code is generated. If the error does not clear, or keeps reoccurring, it is recommended that you doublecheck to make sure your water taps are on all the way and check the hoses for kinks or clogs. If everything checks okay, check the screens on the fill valve for sediment build up. You may need to replace the valve.
Testimonial: "Thank you very much"
