I tried MY Library and Your PDF extensions. Nothin doin. HELP
Go to this site: https://www.manualslib.com/manual/229645/Sony-Str-K6800p.html
There is a GREEN tab above the title [DOWNLOAD]
SOURCE: Sony STR DG 510 receiver manual
Hey there, found it on the sony site... http://esupport.sony.com/CA/perl/model-documents.pl?mdl=STRDG510 Hope that helps.
SOURCE: Lucent MLX-20L Extension Edit
http://dstech1.com/changing-the-name-on-an-extension/
A label can have a maximum of seven characters.
To administer Labels for Extensions from the System Programming console:
Note: When programming on the system programming console, use
the buttons next to the display to specify the letters A through I and
punctuation. Use the line/feature buttons to specify additional alphanumeric
characters for labels. Use the template provided with the System Programming
console to see which line buttons correspond to which alphanumeric characters,
SOURCE: Conversion of .pmd extension files to PDF format
sir,
i do below way (little bit lengthy process)
I have installLinotronic 930 v52.3 printer on my pc which generate PS file format. PS file should be converted to pdf by using Acrobat Distiller 5.0.
SOURCE: Ereader library won't open
Hi.
If you're using the Windows Operating System, the issue may be caused by the Data Execution Prevention feature in the
Windows Operating System or if certain folders used by the Reader
Library Software are corrupt. Please click on the below link and select the desired Operating System to get the troubleshooting steps.
If the issue persists, uninstall the Software and restart the Computer.
Next, disable all the active Software's (Firewall, Anti-virus, etc) in the Computer and reinstall the Software.
Also, please ensure to check the "Launch Software" at the end of the installation. This should resolve the issue.
If you're using the Macintosh Computer, uninstall the Software as per the below mentioned steps:
First, click "Go" and then click "Applications" in the Main menu.
Next, in the "Applications" folder, in the right pane, double-click on the "Utilities" folder.
Then, in the "Utilities" folder, double-click "Terminal".Now, in the "Terminal" text window, type "sudo /Library/ebookLibrary/uninstall-ReaderLibrary.sh". There is a required space between sudo and /.
Next, please press "ENTER" on the keyboard. A confirmation message will appear. Please enter your Password or leave blank if you do not have a user account password.
After the Password has been entered or left blank for no password, press ENTER. You will receive the message that the Reader Library Uninstall is finished.
Now, please click "Terminal" and then "Quit Terminal" to exit the Terminal application in the Menu.
Finally, close all other open windows.
Now, restart the Computer and reinstall it.
Note: Ensure that the Reader is not connected to the Computer while performing any of the above mentioned steps for Windows/Macintosh Computer.
