Bad horizonal board
SOURCE: black screen with horizontal green lines
Hello yoyoxide.
from my experience can be something related with the video card. I recommend you the followig (Hardware diagnostics):
-Look for one of the discs that came with your computer, it should say (Drivers & utilities).
-Boot from the CD. If you don't know how to do it do the following:
1.Insert the Drivers&Utilities Disk.
2.Restart teh computer.
3. When you get the Dell logo, press F12
4.Select Boot from CD/CDRW-DVD (something like that).
-You will get a prompt to run the diagnosics.
-Just follow the wizard
-I recommend you to run diagnostics for everything.
-You will see if you have any problems with your hardware.
It seems that you have a pretty new laptop, so probably it's under warranty.
SOURCE: Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. [email protected]
SOURCE: Samsung Model HLR4667WAX/XAA is making a buzzing sound
This TV is horrible. I have the same one and not even a year replaced the light bulb twice. Very disappointing for a Samsung.
SOURCE: Samsung Plasma TV has horizontal lines of colored dots
I have the same problem, currently searching for a solution. Have you resolved your problem yet? Looking to repair myself, any tips or ideas that you have/expirenced would be greatly appreciated. Thanks, Todd
SOURCE: Horizontal colored lines on Samsung CW-29Z404N
is about c 304 ,100uF/50v. i fix it and it works.
TRY T-CON TEST PATTERNS TO ELIMINATE MAIN BOARD
search the model number for t-con test paatterns in service mode
You have a 55" TV not a 60 " model.
