Question about Lands Phones
I cant call out on my landlline. When I dial a number I get a static beep instead of a dialtone
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 201 Answers
SOURCE: can't dial out
Can you hear the tones when you dial? Is there a (tone / pulse dial) switch or programming option?
Posted on Jul 07, 2007
Anonymous
SOURCE: Handsets give 3 beeps, no dialtone
Either they are not powered up, or the mother has lost power.  Make sure the mother and children bases have power and leave the handsets in the bases long enough to charge.
Posted on May 16, 2009
My phone dialtone is intermittent - how can I return it to normal. It was disengaged earlier and calls sent to mobile. The problem is now sorted but my landline phone is still intermittent.
Usually the dial tone Beep Beep Beep means that you have a voice mail. This is a service or feature that your phone company provides. Sometimes it just a matter of dialing your home number from your home phone and it will prompt you to listen to or erase your messages. If this is not the case, call your phone company and ask them about the feature.
Feb 03, 2015 | Lands Phones
Why no dial tone. Only static?
Check the phone line were it comes into the house there is usually a point where the phone connection from the the TELCO outside wires connects to the inside wiring.
Remove the inside wiring and test the wiring that is on the TELCO side. If you get dialtone the trouble is in the inside wire. If you don't get dialtone call TELCO
Aug 26, 2014 | Lands Phones
Dialtone but no ring only beep
Sounds like its either going offline maybe checking the outlet and the cord that plugs into the base. It may also be the battery needs replacing,it has been run down and charged again too many times.it may hold enough for a dial tone but not enuff to even ring,just beep I stead
Jul 01, 2013 | Lands Phones
How do I get the phone off DND mode
A common problem on the NEC Electra/Elite phone system is that users will pick up the phone and start dialing numbers while hearing intercom dialtone which sounds identical to outside line dialtone. If the user dials 4 then 0, DND is set on that phone ext. The easy way to clear this problem is to go to the phone that is in DND, lift the handset or press speaker and dial 4 then 2. You should get a confirmation tone after which you can just hang up.
Jun 05, 2011 | NEC DTH-8D-1 Corded Phone
How do i program your 20200-1 hand set telephone. it has 13 number memory. that i wold like to program?
To program one of the three emergency buttons:
1) lift the handset and wait for dialtone
2) press the STORE button
3) dial the phone number
4) press the STORE button
5) press one of the three emergency buttons
6) replace the handset in the cradle
To use; lift handset and press an emergency button, the phone dials the number stored for that button
To program one of the ten memory locations:
5) dial a one digit number(0-9) to store the number in that location
To use: lift the handset, press the MEMORY button, dial the memory location digit(0-9), the phone dials the number stored in that memory location
Here is a link to download the manual.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Feb 11, 2011 | Lands Phones
The entry of the phone number dials, but it stops at the last number, it does not connect.
Is the phone actually connecting to the phone line? You can enter a number and tell it to dial, and the phone will, but if you never got a dialtone the call won't go anywhere. If you press the TALK button, do you hear a dialtone? If not, you'll need to check the base unit connection to the phone line. The cord may have come loose at one of the ends, or some problem has occurred on the phone line. Maybe another phone in the house isn't properly hung up.
If you do get dialtone, make sure you're dialing a complete number. Maybe one of the numbers isn't being entered, and the phone line is waiting for the rest of the numbers. This is actually unlikely, since if you are connected but don't place a call after some time, an error message comes from your service provider.
You can also try re-registering the handset. If it's not communicating properly with the base, this will usually get it going.
Then, if other handsets are working and this one doesn't, it's just an electronic failure of some kind in the handset. If it's still covered by a warranty, let Vtech fix or replace it. Otherwise you'll need to purchase a replacement or see what service options are available.
Jan 02, 2011 | Vtech mi6896 Trio Cordless Phone
I can't get dial tone and can't dial out.
make sure the phone is plugged in. You'll need dialtone first, the other issue will fix themselves once you have dialtone!
Feb 10, 2010 | Lucent 1872 Corded Phone
Can i forward my home phone to cell phone
yes, providing you have that service through your provider. It's typically done by accessing your line and dialing *72 if the service is active you'll recieve a stuttered dialtone. then dial your cell phone number. once you've answered your cell the transfer is established. To deactivate call forwarding, from your home phone dial *73. you should recieve a stuttered dialtone confirming that the foward is off.
Dec 22, 2009 | Lands Phones
May 08, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Hpofficejet: will not receive fax. Sender is given our phone number, our phone is answered and we dial our code -- this no longer works. Cannot find manual. Do we reset the number and how, or what...
I just got a new line just for my SF-5100 fax. It was working before I switched to this phone company. I checked the line on a regular phone and it seemed ok. When I plug it up to my fax machine, when it rings I get this static sound instead of rings. One of my customers said when she tried to fax something, she got that same static sound and it would not go through. When I tried to fax her something, I dialed the number and when the fax machine was repeating the numbers it was a series of that same static sound. Then the operator said I should try my call again - so it did not dial through. A few minutes ago, the screen said RX also. Can you please help?
Oct 07, 2008 | Samsung SF 5100 Laser Printer
Lands Phones Logo
55 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
