SAMSUNG 55 LCD SMART TV SERIES 7 FROM 2011 MODEL UN55D7000LFXZA POWER SUPPLY/LED BOARD ARE TOGETHER BN44-00428A. LED BACKLIGHTS ARE ALL WORKING. weak video driver board
SOURCE: no picture
The way to isolate the failure to the power supply would be to measure the voltages going to the backlight inverter board. If all the voltages are normal then is more likely a defective backlight inverter board or LCD controller board.
SOURCE: LN-T4061f samsung lcd no backlight, no sound, no picture
Replacing the capacitors would be a good start. Replace all the ones with the same capacitance and voltage rating even if they do not look bulge.
Let me know if you require further assistance.
SOURCE: 32" LCD HDTV Sceptre model x32, blue led but no pic or sound !
Having the same problem. Took it to a repair shop and they say it is some capacitors and the power supply... Which seems kinda hinky to me... I would think one or the other would be the problem, not both at the same time.
SOURCE: I have an RCA TV
The fact that the screen illuminates properly and does not stay absolutely pitch black means that the backlights are working properly.
A faulty LCD Controller Board (or TCon board for short) could possibly cause the symptoms you describe. The Tcon board is usually located under its own RF shield and will have a large braided steel multiwire cable coming into the bottom of the board and several flat ribbon cables connected to the top by little plastic flip up connectors. A replacement board can be purchased on Ebay for around $70 plus shipping. See the following link for one example:
http://cgi.ebay.com/LCD-CONTROLLER-V320B1-L01-C-RCA-L32WD12-/360142646595?pt=LH_DefaultDomain_0&hash=item53da2cad43
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the item information at the website indicated.
Just don't buy any that say AS IS for their description of condition. That is EBay speak for broken.
Make sure they say TESTED FULLY WORKING in the item description.
The best way to be sure you are getting the right part is to open up your set and check the part number that is printed directly on the circuit board itself. Then look that part number up on the internet or type that number into the EBay search box.
Just typing in the model number of your TV will sometimes give you a few different part numbers so you have to confirm which part is in your particular set.
Make sure any part that you order online has exactly the same part number as the one you are replacing. Sometimes it it just the last few digits that are different and it can make a difference.
Here are some links to some excellent LCD Troubleshooting Guides from another expert (BUDMRTN) that you can read through and get an idea of the LCD repair process:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
http://s807.photobucket.com/albums/yy352/budm
http://en.wikipedia.org/wiki/Capacitor_plague
Please leave a Thumbs Up rating on his pages if you find his guides helpful.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
