QC-8637 camera deliver crystal clear images. Backward compatible with standard analogue equipment such as DVRs
J15AU 09 SECUR /03/ :44 am Page 436 OUTDOOR & SPECIALTY CAMERAS PROFESSIONAL HIGH DEFINITION CAMERAS SPECIAL APPLICATION CAMERAS 720p AHD OUTDOOR CAMERA WITH IR 600TVL HIDDEN CAMERA MIRROR Capture your surroundings with these bullet and dome high definition camera's. Featuring the latest AHD (Analogue High Definition) technology, these camera deliver crystal clear images. Backward compatible with standard analogue equipment such as DVRs, video splitters, video balun, etc. Designed for use where concealed high security is the main requirement such as retail stores, offices, ATMs, museums, art galleries etc. To most people it looks like a simple convex security mirror but embedded behind the patented reflective layer is a 600TVL security camera. QC-8639 Features built-in colour digital noise reduction 3.6mm lens with standard BNC for connection to your DVR Ideal size for easy wall mounting. QC-8637 Supplied with power supply and 18 metre coaxial cable fitted with BNC connectors. Two models available. Image Sensor Effective Pixels Electronic Shutter Video Frame Rate IP Rating Min Illumination Video Output Day / Night IR Type IR Range Power Requirement Recommended Power Supply LET S SECURE 720p 720p QC Megapixel, 1/4" CMOS 1280 (H) x 720 (V) 720p 1/25-1/10,000 Sec 25fps (PAL) 3.6mm IP Lux with IR 1 channel BNC IR cut 30 IR LEDs 10m MP-3011 Type Bullet Dome QC-8637 QC-8639 QC Megapixel, 1/4" CMOS 1280 (H) x 720 (V) 720p 1/25-1/10,000 Sec 25fps (PAL) 3.6mm IP Lux with IR 1 channel BNC IR cut 30 IR LEDs 10m MP-3011 Qty 2+ Qty 4+ $ $ $ $ $ $ TV System Resolution Power Requirement Current draw Image sensor Type Mirror 600TVL QC-8631 $ TVL HIDDEN CAMERA - PIR APPEARANCE High quality camera disguised inside a housing that appears to look like a PIR. The power and video cables exit through the rear of the unit so are relatively concealed from prying eyes. Housing is compact and will fit unobtrusively in the corner of any room Equipped with a high resolution 800TVL Sony sensor for superior image capture. SENSOR INSIDE 1080p INFRARED BULLET IP CAMERA POWER OVER ETHERNET (PoE) QC-8652 Sensor Sony 1/3" Sensor brand Sony SuperHAD II Sensor resolution (H x V pixels) 976 x 582 Resolution (horizontal TV lines) 800 Minimum illumination (lux) 0.01 (IR off) / 0 (IR on) 3.7mm With UTC (Up the Coax) OSD control Power supply Current draw 200mA 47(L) x 47(W) x 120(H)mm This 1080p Infrared Bullet IP Camera over PoE is constructed using professional grade material to help to prevent deterioration, and rusting. The camera can be mounted any indoor or outdoor situation. With PoE feature, the installation work is simplified and made easier so that you save both time and money. It is an ideal HD IP camera for applications work or home etc. 2.0 Megapixel CMOS Sensor 4.0MM 36 LEDs with 20m IR range H.264 Compression Format Support P2P, Video Push Transmission up to 15FPS/2MP PoE power supply: 48VDC, 0.5A Support Onvif : 280(L)mm x 80(Dia.)mm 1,080p Type Bullet Type PIR 800TVL QC-8652 Qty 2+ Qty 4+ $ $ $ TVL HIDDEN CAMERA - SMOKE DETECTOR APPEARANCE QC-3122 High quality camera disguised inside a housing that appears to look like a smoke detector. The power and video cables exit through the base of the unit so are completely concealed from prying eyes and cutters. Qty 2+ Qty 4+ $ $ $ Housing is compact so will fit unobtrusively on the ceiling Equipped with a high resolution 800TVL Sony sensor for superior image capture. DO A FRIEND A FAVOUR SENSOR INSIDE If you have a technical friend or someone who may be just interested in some of the products we stock, simply mail or his or her address to: Catalogue Department Jaycar Electronics: PO Box 7172 Silverwater, NSW 1811 or to QC-8650 Sensor Sony 1/3" Sensor brand Sony SuperHAD II Sensor resolution (H x V pixels) 976 x 582 Resolution (horizontal TV lines) 800 Minimum illumination (lux) 0.01 (IR off) / 0 (IR on) 3.7mm With UTC (Up the Coax) OSD control Power supply Current draw 200mA 110(Dia) x 60(H)mm 800TVL 436 QC-8631 PAL/NTSC 600TVL (use MP-3011) 500mA 1/3" colour Ex-view CCD 350(Dia) x 200(H)mm Freecall Order Hotline: Type Dome QC-8650 Qty 2+ Qty 4+ $ $ $ Prices in Australian dollars https://docplayer.net/26242225-Security-surveillance.html
SOURCE: user manual for signet DVR model qv 3083
i had the same problem and i was googling like crazy and no results, i did find my manual and in fact the model is diffrent to the one on the manual, i googled the manual model and i got all thee drivers, software and manuals. go figure. anyway i will upload the manual for you http://pdfcast.org/pdf/1275304250 download it and enjoy!
