you will have 2 lines at the tank. 1 is the supply line with one end having the fuel filter on it and sitting at the bottom of the tank. it generally runs to the inlet side of the carb. the output side of the carb usually goes to the primer bulb inlet, the last hose usually goes from the outlet of the primer bulb back to the fuel tank but only goes in 1/8 to 1/4 of an inch. it should only be in far enough to seal the hole and allow the fuel back in to the tank
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/kelly_69a0cf1b13789df1
