SOURCE: converting wma files to wav files on olympus DDS player version 7
When using the DSS Player v7 software the program is unable to convert WMA to WAV. The option you see there only works when it is a .dss file that needs to be converted to .wav. In order to convert WMA to WAV you will need to locate a third party software program that does this type of conversion.
Go to google and search on WMA to WAV conversion editors.
SOURCE: Olympus DS-30
sometimes formatting will reset the file number... format through the recorder..
SOURCE: We have an Olympus DS-40, but wish to create DSS files
the AVS audio utility should do the job. You can download a trial copy at www.avs4you.com try it out I think it's what you want. Good Luck
SOURCE: I have the DS-2400.
Try importing the file again (not copying and pasting, but importing), and then looking in the "Finished folder." When I cannot see a folder this is where I have always found them--I have never figured out why this happens and the company I get my files from cannot figure it out either, but that is where they have been found. If you find your file there, you need to right click on the actual voice file and it will turn "blue," select "move the folder" to A,B,C,D, or E. Sometimes once you select the folder you want the voice file to go to it will just go right there, other times there will be a second step in the process where it asks you to click, finished, unfinished, pending, or cancel job. You need to check "unfinished" before the job will transfer to the folder you have selected.
I hope the above helps, as it has been the only solution I have found.
