SOURCE: Panasonic x70 locked
hi if the code isnt 12345 then the chances are somebody has changed it and you will only get 5 trys at guessing the code.
The problem with your model of phone is that the newer panasonic phones cant be unlocked using a code you will need to get a flash lead and the panasonic flash programme to reset the phone and reset the code.
You can either try and track down a flash lead and programme if you are unable to locate the lead and software then the only other way is to goto a phone repair shop and pay them to unlock the phone and reset the security code.
Give this a try first though if you use ask.com and type in "panasonic unlock calculater" or try "free panasonic unlock calculater" you might find a code generater programme thats only if somebody has manged to crack the code calculater i know their is one for nokia so give it a try.
The only other way you can get this done if the phone shop dont do it for you is find a web site that can unlock the phone remotely these usually charge for this service but not to much about $10 or £5 about that much and these can unlock your phone remotely you can also use ask.com to search for this service their should be a few online so have a look.
If you need further assistance let me know or if you dont understand what i told you then just ask or if you cant locate the unlock calculater.
Try also searching for "free security unlock calculater"
Let me know how you get on ok
SOURCE: Achiever 260 AF for pentax
Check the voltage trigger of the flash, if you're under 7vdc. Then you are good to go.
[email protected]
SOURCE: Pentax x70 operating manual in russian
Good Afternoon,
After extensive searching for you, I am only able to come up with manuals in English, French and Spanish.
For some reason they do not list the X70 model on the pentax.ru site, however you should be able to translate the pages using Google translator from the English version of the manual.
It will often say that the document is too large but if you break it down (I think pages 47-61 should be good enough... it's the quick start and basic settings section) you should have more luck.
I hope this helps a bit.
Lompanow
