Question about RCA Audio Players & Recorders
I have a problem with My pioneer djm 600.. basically a noise comes out the speakers ,plugged or not directly.. Playing Cdjs 800,mixer,focusrite 2i4 and speaker krk and the noise comes out,especially with bass.. zzz zzz zzz! Rca direct to speakers,same story.. when I use ableton or NI mikro mo buzz no noise everything is fine.. what do I do?
6ya staff
SOURCE:
Anonymous
  • 682 Answers
SOURCE: pioneer djm 800 will only play through 2 channels on mono??
try to clean your fader with contact cleaner and move it many times after cleaning -check your connection plugs(buy it from radio shack near you.
Posted on Apr 14, 2009
micmor100
Morne Olivier
  • 257 Answers
SOURCE: When moving the bottom knob on channel 1 and 2 of ...
That sounds like you could have some dust built-up on your sliders. Get yourself some dust repellant spray or silicone spray normally found at you nearest computer store. That will definately sort your problem
Posted on Jun 08, 2010
DJAJ-NE
DJAJ-NE
  • 54 Answers
SOURCE: no sound coming from headphones using my dj mixer.
hii there, pls try to use another headphone on your mixer, if you get the same problem. It means your headphone have no problem. Problem is with the the jack of your mixture. Open your mixture and check the jack properly attached internal.
Dj Ajay
djajay@inbox.com
Posted on Jun 14, 2010
Ben Armstrong
  • 360 Answers
SOURCE: I have a djm 400
Does it buzz through cans? (headphones). Try listening on headphones (turn off any amps and speakers) on cue to each channel you use and to the master output. is it stil there? if so it's an all round earthing fault. If it's all good through the cans (sorry...I mean headphones), try it with the amp/s on again. If the buzz is back it souds like the screen on the main audio output connecters has come off inside.
It's a quick fix, but if you have never used a solder iron, take to someone who has.
Posted on Jan 07, 2011
Testimonial: "Great start need a little more help"
George Young
  • 104 Answers
SOURCE: buzzing noise z4 logitech speakers
Hi Haley,
I also enjoy good Music and excellent sound from my speakers that i have and know what you going through. There is two problems that i see here. One is that your bass speakers is dying on you from the excess bass that has been exerted throught it or have you tried lowering the adjusting bass from the contol panel?
Try adjusting the bass and if that doesnt work aleast you've identified your problem.
Thanks Haley for using Fixya.Good Luck.
G..
Posted on Nov 09, 2011
Pioneer DJM 600 Master Out 2 Left Side Doesnt Work. any help please?
it could be a few problems,
1 - the left master connection to the board has come away (you would have to open up the mixer to detect this.)
2 - the master fader is faulty (you can tell this by checking your master level indicators are both on whilst music is playing, or tapping the fader.)
My advice would be to have it serviced or if under warranty speak to the store you bought it from. But if you feel confident and know what your doing u can find replacement parts on ebay etc.
Hope this helps a little
Jul 17, 2012 | Pioneer DJM-600 Silver Professional DJ...
When moving the bottom knob on channel 1 and 2 of the pioneer djm 600 mixer there is a slight interference sound coming through the speakers. Channel 3 and 4 are fine
May 21, 2010 | Pioneer DJM-600 Silver Professional DJ...
Pioneer DJM 600 mixer keeps blowing ic 557 fuse on power supply board
I repair DJM 600 for many years. :) The reason for the burning of IC 557 (+8V H 600mA ) is invalid amplifier for headphones!!!
Replace IC 310 and IC 312 (in big mainboard), and replace
IC 557with original fuse 600mA
!!!!!CHECK YOUR HEADPHONES!!!!!! This is the cause burning amps.!!!!!
DJ Iskren
Oct 03, 2009 | Pioneer DJM-600 Silver Professional DJ...
Pioneer djm 800 will only play through 2 channels on mono??
Apr 11, 2009 | Audio Players & Recorders
Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
New DJM 600 User
Get yourself a manual. It will help you. You can DOWNLOAD A FREE COPY of the PIONEER DJM600 INSTRUCTION MANUAL from HERE.
Now, you have to use the CUE button function on each channel to select what you want to hear when you cue things in the headphones. Last, you control the volume of the master cue in the headphones using the CUE volume of the headphone CUE section.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Nov 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer djm 800. (dj mixer) when turning the master gain volume it doesnt turn the volume up or down unless you put pressure onto it.
apply some spray (lubricant contact cleaner)from radio shack-----to master gain volume and move it up and down many times.
Sep 09, 2008 | Pioneer DJM-600 Silver Professional DJ...
PIONEER DJM 600 MIXER KEEPS PEEKING RED SHOWING HI SIGNAL AT LOW VOLUMES
check your input (cables and device)for bad or short circuit cable-bad plug--connection between inner conductor and shield. of the cable(test with new one)------you can disconnect inputs one by one until you find the bad one.and change it.
Aug 27, 2008 | Pioneer DJM-600 Silver Professional DJ...
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
