Question about Hardware & Accessories
Sony CFD-ZW755 standby mode problem. Will only play for 1 hour from set start time. Is something limiting it to 1 hour only?
I've programmed it before to play for more than one hour, typically 3 hours. I can program the source, start time, shutoff time and volume. It will start at programmed start time, but, will only play for 1 hour. When I check the shutoff time after programming it, it has reverted back to exactly one hour from the start time, no matter what tim eI set for the start time, the shutoff is set to hour later. I can not get the shutoff time to stay programmed. Is this feature broke or is there something limiting the play time to only 1 hour? If the later, how do I turn off this limit?
Anonymous
SOURCE:
Anonymous
  • 137 Answers
SOURCE: Honeywell programmable Thermostat won't hold time or program
Most thermostats use a six volt transformer for a power source, similar to a door bell, you can tell if yours does by looking at the wires that are attached to the thermostat.
The wires will be thin with just a single strand if you have these wires then you have a transformer, try and find the transformer (good luck) test it with a voltmeter if it fails the test that's it, if not, call the man. Probably it though.
Posted on Feb 15, 2009
Anonymous
  • 121 Answers
SOURCE: receiver switches to standby without notice
This receiver is likely to be overheating or has a shorted speaker wire. If the unit is very warm when it shuts down then it is in need of some additional ventilation. Onkyo's tend to run hot so this is critical for proper operation. A speaker wire problem could also cause an issue when the unit detecs a no load situation.
Posted on Feb 27, 2009
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
time, press and hold the On/Off button until
the red power light and LCD display begin to
flash. This signals that you have entered the
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
When the coffeemaker shuts itself off, two
tones will sound.
NOTE: Automatic shutoff may be
programmed either before or during coffee
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
40 minutes and 25 minutes have already
elapsed, the unit will shut off automatically
after 15 minutes (40 minutes minus the 25
elapsed equals 15 minutes).
-Tha Mp3 Doctor
Posted on Apr 15, 2009
Morten Bergendahl
  • 60 Answers
SOURCE: Cannot reduce water volume setting in program mode
I`m sorry, but there is no Reset function on this model. But you can try anyway; Turn off your machine to standby. Push and hold the P-key. If it works you get OK in the display.
If it don`t, you either just live with the problem (you can always stop any process by pressing a key) or you have to go to your nearest servicecenter and get the touchdisplay changed. This however, is rather expensive.
Posted on Jul 28, 2009
Odis Pitts
  • 15 Answers
SOURCE: programing a keyless remote for a 97 buick lesabre limited
go to "programyourremote.com" and see if they can help you with your paticular vehicle...
Posted on Aug 11, 2009
I have a zs-s41p boom box that takes an ipod and CD. I'm not getting any sound at all. Radio, ipod or CD player. Help!
Check the back of the unit for possible shorts in the speaker wires, no change! take the boombox to a service centre for a repair estimate.
Aug 13, 2012 | Sony CFD-ZW755 Radio/Cassette/CD Boombox
Hi, i have a aux cable and i plug it into the jack. will it play my music? if so, what setting should i put it on? thanks.
A cable will not play music. It WILL convey a signal from a source to something which presumably CAN play it.
This model has no inputs or outputs.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-CFD-V17-manual/id/266ci877/t/2/
Jun 19, 2011 | Sony CFD-V17 Cassette/CD Boombox
Radio plays with batteries but when power cord is used the display says check battery.
Connect the power cord to the radio without the batteries inside, i mean remove the batteries from the radio, and see what it will display.
May 29, 2011 | Sony CFD-ZW755 Radio/Cassette/CD Boombox
Where can i get a replacement remote for cfd-zw755
you can find it at sonystyle.com just type in model #
Feb 12, 2011 | Sony CFD-ZW755 Radio/Cassette/CD Boombox
This model boombox is no longer reading disks in the cd player. What could I try to fix the problem?
Hello,since this unit is a top loader its very susceptible to dust and dirt on the laser.I recommend opening the cd door ,locating the laser( small bluish or clear lens) and gently rub a dry q-tip over the top of it.
Jan 12, 2011 | Sony CFD-ZW755 Radio/Cassette/CD Boombox
No sound through speakers or headphones , cd spins, cassette tape turns.
Need more information - Has it ever worked? Can you hear the radio when its on - etc.
Jul 04, 2009 | Sony CFD-ZW755 Radio/Cassette/CD Boombox
Turning alarm on and off
I'm afraid I don't have a manual, but I could walk you through the steps...
1. Press the clock/sleep/timer button twice.
2. Press enter button.
3. Turn dial to set hour for alarm to start.
4. Press enter button.
5. Turn dial to set minute for alarm to start.
6. Press enter button.
7. Turn dial to set hour for alarm auto-shut off.
8. Press enter button.
9. Turn dial to set minute for alarm auto-shut off.
10. Press enter button.
11. Turn dial to select either Radio or CD alarm setting.
12. Press enter button.
13. Turn dial to adjust volume of alarm.
14. Press enter button.
15. Press standby button. Alarm is set.
I hope this helps! Best of luck finding a manual if you still need one. :)
Jun 03, 2009 | Sony PSYC CFD-E90 Radio/Cassette/CD...
The CD starts to play and then stops and it makes a static noise. It is also random at the point at which it stops playing. Have tried multiple CDs.
I would try a dust cleaner can and spray inside to clean; also get a cd cleaner hopefully you can get one with brushes on it and see if that does the trick. you can even go to sony website and get answers.
Mar 29, 2009 | Sony CFD-ZW755 Radio/Cassette/CD Boombox
Audio Problems
play the cassette in another player. you might have to change your setting on the player. you can also try a cassette cleaner/demagnatizer to clean the cassette. also try the sony webstie for answers
Jan 15, 2009 | Sony CFD-ZW755 Radio/Cassette/CD Boombox
Hardware & Accessories Logo
90 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Thomas F. Schneider
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
