You need to make sure the inner pot is making complete contact with the center heating element in the bottom center, and that the metal surface of the center contact is free of contaminants like oil or food particles. If this does not clear the error message you might need to replace the contact switch on the bottom of your unit. Switch replacement procedure depends on the model of your unit. Try doing a search for the repair manual for your particular model number.
SOURCE: Cooks esentials pressure cooker
osborne, that link is no help whatsoever.
Theres a yahoo group that has this pressure cooker manual and lots more manuals: http://groups.yahoo.com/group/PressureCookerRecipes/
I don't believe you will find one without someone sending it to you, by joining this group, someone should be able to fax you or email one to you, good luck and let me know if you need further help
SOURCE: I can't open my new Ultrex 2 Pressure cooker model 11302
It's almost certainly due to atmospheric pressure. Warm it slightly and it will open.
I had the same problem with an underwater dive torch. Left Johannesburg (1000 metres above sea level) and went to Mauritius (10 metres above sea level) and I couldn't open torch!
SOURCE: Need new nonstick pot for my rice cooker TAYAMA TRC-07
Please call 1-866-9TAYAMA and they have all the parts you need
SOURCE: Salton RA3 3-Cup Rice Cooker Question
Put equal amounts rice and water (up to 3 cups only) in liner pot, plug in, put lid on, flip little front switch. 10-15 minutes later it will be done and the pot will switch to "warm" mode by itself. Gently fluff with paddle before serving. You can also add salt or other seasonings to the water/rice mixture before starting.
SOURCE: RIVAL Crock Pot 3350 - Replacement of Cooking Pot
I need a new liner for my Rival smart pot. the crock bowl broke.
Here is a tip that I wrote
that will help you with using your rice cooker to steam
your veggies...
How
to Steam Vegetables in your Rice Cooker
heatman101
