My machine flashes "READY" then "Check Network" then "Setting 103"
what maybe have I missed? so I can print?
It sounds as if you have an IP address conflict, are you set to Dynamic or Static? if static set the last Octet ie:192.168.0.xxx to something at the top of your ip range, print out a config sheet from the Copier/MFP by going into user tools printer config page and print.
at the bottom r/h side is the host name of the printer typically with Ricoh it will be Rnpxxxx
set the hostname on your tcp/ip port to the host name ensure that you have dns information set on the MFP and your pc and also gateway info on both and that should fix the issue once your reboot the pc and MFP.
if this resolves your issue please rate me accordingly.
Thanks
The Gateway Info was not set properly on my MFP. Now everything works fine, thanks to your help. Many, Many Thanks...!!!
