SOURCE: sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
SOURCE: locked out of my cs2 safe
If you registered your safe with the manufacturer they will normally let you know your combination if you have registered the safe.
If not you will need the serial number on the side of the safe and you will need a notary stamped paper explaining you are the rightful owner of the safe.
Costs will apply to the Notary and possibly from the manufacturer.
Testimonial: "thank you very much your help was excelent "
SOURCE: My Bunker hill safe Batteries died and the keys are inside.
Check this out:
http://www.fixya.com/support/t1062111-bunker_hill_safe
(no need to re-invent the wheel, other experts have given solutions first)
you would need to hot wire the batteries for the code to work but if the batteries have gone flat then it needs to be re-programmed again ,only one soloution here and thats to open it with a radial cutter
