SOURCE: Non-stick surface damage
Contact these guys and they should be able to supply replacement grill plates cheaply; http://www.esalton.com/control/contactus In general the current view is that low quality aluminium alloys, when used for cooking can put enough aluminium into the food over a long period of time to POSSIBLY influence certain conditions such as alzheimers disease, amongst others. There is a certain amount of aluminium in many things we eat or drink, regardless of what it is cooked in. If you use the grill every day then i would recommend replacing the plates, especially if the aluminium itself is becoming pitted, however I have used similar, lower quality grills before with coating worn and haven't gone mad yet. If in any doubt then replace the plates, but i think you are being over cautious here. If you find that food is now sticking to the grill, try grilling half a handful of salt with a little vegetable oil for 10 minutes or so, spread over the whole plate - a certain amount of "non-stick" can be achieved like this, although if cleaning the plates with detergent, this will soon need doing again. Hope this helps :)
SOURCE: bottom plate replacment
theres lots of posts here regarding george foreman products.
there does,nt seem to be anywhere to buy replacement parts.
I,d suggest buying a new alternative product, with a more stable background, and reliable service and replacement parts. i.e russel hobbs or tefal et,c.
Mike @ Compurepair.
SOURCE: Stuck Grill plates
What happens is that the upper post (see the back of the plates; there's a quarter inch wide post) slides into a slot not designed for it (too small). To fix, find the post. Slide a table knife in between the plate and the griddler, and twist. This should un-jam the post and free the plate.
SOURCE: can i buy replacement grill plates?
It would cost as much as a new unit, but try www.grillparts.com
SOURCE: I have a brand new cuisinart gr-4n grill with a
Try visiting http://www.cuisinart.com, you can check there the nearest authorized parts dealer in your area.
