Heating & Cooling Logo
Jeramie Posted on Mar 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fridgedaire 8000 btu heat pump compressor runs all the time even with it in off position
Michael Youngman
Level 2:
Sergeant:
  • Expert 296 Answers
  • Posted on Mar 30, 2019
Michael Youngman
Expert
Level 2:
Sergeant:
Answers
296
Questions
0
Helped
180467
Points
743
I couldn't have explained it better Darius. Good job
Darius Weaver
Level 2:
Habit-Forming:
New Friend:
  • Expert 45 Answers
Darius Weaver
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
45
Questions
Helped
26170
Points
182
Is this an outdoor unit or indoor? the most common cause is a stuck compressor contactor - located in the outdoor unit. The contacts tend to get pitted-up. Eventually they can weld shut. This can cause serious damage to the system. It is good practice to replace the contactor every few years or when pitted, just like spark plugs in a car.
Another cause would be a shorted thermostat cable. This can be caused by a weed-eater hitting the wire outside, or a wire-staple digging into the wire too tightly, rodents chewing on it, or just bad wire.
The thermostat itself could be bad, sending a signal to the outdoor unit when it isn't supposed to.
4 Related Answers
Anonymous
  • 143 Answers
  • Posted on Jul 24, 2008
SOURCE: compressor for HQ2082YW
look in the phone book under air conditioners, parts and supplies.
Anonymous
  • 221 Answers
  • Posted on Feb 03, 2010
SOURCE: is 8000 btu.burner enough heat for general use
Hi, 8000 btu is a medium size burner, simmer burners are around 4000 btu, The largest are around 12000.
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Jun 25, 2010
SOURCE: RVP 8000 A/C just experienced slight power surge. Compressor on.
I'm leaning toward sticky relay as well, but if you want to confirm it's not thermostat, remove thermostat from wall, and temporarily disconnect the yellow wire from thermostat (compressor) when/if, it happens again. If compressor stays running, I'd say relay for sure.
Just for future reference , Gray wire from thermostat is low fan, green wire is high fan, yellow is compressor, blue is ground. ( For cooling side) The red is 12 v + to furnace and white is negative to furnace.(heat side)
Testimonial: "Many thanks. After cool night with breaker off the compressor unit worked fine the next morning, then stuck again on in the p.m. Next day same thing. Three days later all is now working well. Must have been a welded contact that somehow cleared itself. Thanx again!"
Rinoo Kumari
  • 2973 Answers
  • Posted on Sep 25, 2010
SOURCE: I have a Dometic Duo Therm 13500 BTU roof mounted
Scott,
I feel it is a faulty thermostat switch that is causing the problem. If you replace it, your problem may get solved. The fan switch has nothing to do with the compressor. It is the thermostat that has all to do with it. Fan is only to blow the air fast or slow. The thermostat switch controls the working of the compressor.
Will a th5000 work with a ruud dual fuel
Are you talking about a pro 5000 Thermostat??? if so then NO it will not work.With this stat you do not have a temperature lock on the heat pump. Say you don't want the heat pump to run below 25 degrees. it won't shut the heat pump. And you don't want the heat pump to run at the same time as the furnace. With the Pro 8000 3 heat and 2 cool thermostat you can lock out the heat pump at 25 degrees outside an turn the furnace on. You will have to install an outdoor thermostat hooked up to the pro 8000 it usually comes with the stat. Honeywell products.
Heat pump compressor wont come on in heat mode, works fine in cool mode, we get heat occaisionally for about 2 min, then the compressor shuts off. it is a fridgedaire window unit.
Try setting the thermostat at a normal heat setting. By raising the temperature too high the unit thinks that the heat pump won't be effective and go into strip heat mode.
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
1helpful
2answers
I have a single room 8000 btu kennmore air conditoner was making loud squealing noise when compressor kicks on and now it makes no noise and does not cool at all please help
sounds like the compressor may have died on you. the compressor isnt running you might as well trash it sorry for the bad news but it probably isnt worth trying to replace a compressor in a system like that it would drive you crazy and take forever if it could even be done.
Top Heating & Cooling Experts
Paul Carew
john h
