It sounds like the issue you are experiencing with your Olympus TG630 camera is related to power. The camera turns on briefly and then the screen goes blank. It also doesn't turn on when plugged into a laptop.
Here are a few things you can try to troubleshoot the problem:
If the above steps do not resolve the issue, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It is also possible that there is a problem with the camera's power switch or the power supply circuit which could require a professional to repair.
SOURCE: Olympus digital camera wont turn on
First: thank you, for suggesting battery terminals. It was failing to power on intermittently for some time; the problem became more-and-more frequent until it would not come on at all. Cleaning the terminals saved my camera! Second: for others, let me suggest plain old pencil erasers as a good way to clean electrical contacts (something I learned from HO model railroads as a kid). A vigorous rub with the brand new eraser on the end of a pencil cleaned the battery contacts inside the camera.
SOURCE: olympus FE290 cameras screen is blank i.e does not capture image
ccd sensor may be malfunctioning and need repair
olympusamerica.com/repair
SOURCE: OLYMPUS FE360U BATTERY DOES TURN ON
the LCD screen is malfunctioning
Repair it with the help of a professional immidiately to prevent further malfunction
SOURCE: C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen.
Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
