SOURCE: 3 phase sunbed
You have to get a 3 phase circuit put in. Call an electrician. Some electricians may not even know how to do 3 phase power though. Call around.
SOURCE: Panasonic Split System Air Conditioning.
we have a old national air con cassette model cu-5chv11p , works for three days , then controller comes on e4 error ,and then switches off , and will not reset .
SOURCE: Need to convert 3 phase Hobart dishwasher to single phase
It will not be inexpensive to convert your dishmachine over to three phase. With everything that you will need to replace, depending on the model if converyor or not it may run close to what it costs to have 3phase run to the building that you plan to move into.
SOURCE: Need to change oven from 440 3 phase to 220 single
It can be done with a transformer, 480/ 240 single phase transformer to get the lower voltage. Then the oven will require some wiring changes to get all the elements and controls connected to two hot wires instead of three. The transformed will be sized to the wattage rating of the oven. This is a only basic description of what needs to take place.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: can i convert a 3 phase 10hp qrs compressor to single phase?
Search the 'net for phase converters. I have read articles about making your own phase converters from old 3 phase motors----Fine Woodworking mag.
