Question about Hobart Dishwashers
I have hobart dishwasher profi amx with error link missing ste how do i fix this and what does the error mean
4 Suggested Answers
6ya staff
SOURCE:
bigg t
anthony james
  • 640 Answers
SOURCE: bof error hobart amx
Sorry so late for the reply.Im a hobart tech and i dont recall this model of your unit,are you sure the model isnt a am-14 or am-15?
Posted on Aug 24, 2008
Anonymous
SOURCE: hobart amx/aux-s dishwasher "bof" error code
press the 1st and third buttons on the display nxt to the start button then press the start button,this will change the the display to something like BOF1 then allow the achine to fill the rinse tank you will know when this has happened as the display will go out (all of it) then you can turn on the machine using the button marked with a I the start button will light red allow it to go green and you are ready to go ... if when you are boffing it it changes to FIL the your water pressure is to low good luc fella
Posted on Mar 04, 2009
b_lea76269
BOB LEA
  • 62 Answers
SOURCE: Hobart glass wash machine amx-gh continue washing does not advance to the rinse cycle with no error code
only a suggestion is it heating up what i remember it want move on until it heats up to it's working temperature, good luck
Posted on Sep 22, 2016
Amx 90 series hobart dishwasher was opened before it was ready for about 10 seconds...it is now reading UL sounds like it is draining but will not reset itself....
UL means there is too much water in the wash tank. It will continue to run the drain pump u ntill the water level is correct. If it is not pumping out then there could be a problem with the pump, blockage or relay fault on pcb
Sep 26, 2017 | Hobart Dishwashers
Sep 22, 2016 | Hobart Dishwashers
Bof fault code
The display of "BoF" on the display is simply a confirmation code to commence the next operation on the dishwasher. It is not a fault code.
Refer manual of a AMX model Hobart dishwasher. If your model is different the general codes are same.
http://www.dishwashers-direct.com/uploads/Operating%20instructions/Hobart/AMX%20RANGE%20OP%20MANUAL.pdf
Apr 19, 2014 | Hobart Dishwashers
Dishwaher hobart amx 900-16 has fil displayed what does this mean?
fil massage mean the water not came in the booster tank , maybe the water pressure is low or the solenoid valve is defective, always this massage come to me i change solenoid valve then it will work, check and tell me
May 12, 2012 | Dishwashers
Looking for a hobart amx dishwasher wiring diagram from 3 phase converting to single phase
sr. we are using Hobart dish /w but not working this properly .when i start d/w display red light coming but not green light also heater working water coming can you help me
Jun 04, 2009 | Hobart Dishwashers
Bof error hobart amx
Aug 16, 2008 | Dishwashers
Hobart amx/aux-s dishwasher "bof" error code
Mar 13, 2008 | Dishwashers
Hobart dishwaser
I have attached photo of my ecomax dishwasher machine please let me know how to fix the error, it’s still all 4 lights are flashing
Jan 14, 2008 | Hobart Dishwashers
Dishwashers Logo
311 people viewed this question
Top Hobart Dishwashers Experts
GPEC
Level 1 Expert
Jason
Marvin
Marvin
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
