SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
SOURCE: Panasonic KX-TGA101S base not charging.
Here are a couple things you can try.
Clean the charging contacts, this can be done two ways. The manufacture's recommend using a pencil eraser. I recomend using a q-tip and some rubbing alchol. Just rub the alchol soaked q-tip on all the metal contacts on the bases and the bottom of the handset.
Gooo luck.
Hope this helps
SOURCE: panasonic cordless phone KX-TG9331, the
If you have listened to all messages on the answering machine, then this is the "tone" that the phone company sends out for those people who have paid voicemail with the carrier.
Page 41 of the manual - "if the handset still indicates there are new messages even after you ahve listened to all new messages, turn it off by pressing and holding [OFF] until the handset beeps.
Page 40 of the manual - "Turn VM tone detection on/off - the default setting is "ON" 1. [Menu], then press #332 then choose [OFF] - now when the phone company sends a tone out to your phone it will be ignored.
SOURCE: Panasonic cordless handsets all say line in use
I had the same problem. Something makes the phone's memory get "stuck." Take the battery out of the phone for a minute and then put it back. Then unplug the phone and plug in again. You need to do this with all extensions. The problem goes away.
SOURCE: english manual for Panasonic KX-TG1100CE cordless phone
You can downoad it from this link: http://phone.manualsonline.com/manuals/mfg/panasonic/kxtg1100ne_kxtg1102ne_kxtg1103ne.html or you can buy a copy from : http://www.cordless-phones.uk.com/cordless-phones/digital-cordless-phones/panasonic-kx-tg1100-phone
................................................sodeep
