Car Audio & Video Logo
kamran bits Posted on Mar 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My clock resets when i turn my deck off kenwood rxd-v323 what i do is first press the power button than it enters into standby mode than i switch the power off this is normal or not.
jerry fitz
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Mar 30, 2019
jerry fitz
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
30244
Points
56
You need to check your 12v constant wire on radio. This is what keeps memory in the radio. Which keeps the time saved
Testimonial: "i have kenwood rxd-v323 hifi stereo system i dont see any 12v constant wire. i think you are saying about car sterio"
  • jerry fitz
    jerry fitz Mar 31, 2019
    Oh I'm sorry I didn't look up model number. That's odd the a home stereo does that.
  • kamran bits
    kamran bits Mar 31, 2019
    so clock reset is normal
CJ Rock
Level 3:
  • Master 4,424 Answers
  • Posted on Mar 29, 2019
CJ Rock
Master
Level 3:
Answers
4424
Questions
0
Helped
1642730
Points
15013
Try a factory reset
my clock resets when i turn my deck off kenwood rx - k1-e2gnporob5cgbrww2oo45gjp-3-0.png
Testimonial: "the reset method you mentioned is not working. what i have done is pressed power and stop botton of cd section while holding turned off it and released it and power it up"
Chris Walker
Level 3:
Top Expert:
  • Kenwood Master 1,573 Answers
Chris Walker
Kenwood Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1244642
Points
21965
5 Related Answers
A
Anonymous
  • Posted on Jul 12, 2007
SOURCE: standby mode
It happened to me.. a FAx to Enrique. in California.
Anonymous
  • 752 Answers
  • Posted on Sep 11, 2007
SOURCE: How to turn off this blasted DEMO mode on MP235
Once in standby you have to press and hold the button to get into the menu. Once in the menu, you use the joystick control on the right to navigate to "Demo" and toggle it to "off" (can't remember off the top of my head... you either have to press the joystick in and hold it to toggle or just move it up/down...). Once done, just press Source to exit.
Anonymous
  • 3 Answers
  • Posted on Jan 04, 2009
SOURCE: Panasonic PT-AX100U-EC
I just repaired mine with some oil for the iris assembly.
The problem is the iris is either slow to respond or doesn't respond to it's controller. The cam should snap back to it's resting point and move freely. It needs to be re-oiled. Mine would move but sluggishly like it was sticky. There are TWO pivot shafts to oil. One on top and one on the bottom. The bottom one can be accessed by removing the bulb. You can see the bottom cam while the bulb is installed. This is a good point to test the iris movement at.
You need to have some mechanical ability. If you don't think you can do this then don't.
First remove the bottom bulb cover. Now get a flashlight. Look in the area that bulb is pointing towards. In the left corner of the side towards the front of the unit where the lens is, you will see a brownish cam. It has a spring around it.
Take a small screwdriver and move it to it's extent like a wheel. Let go and it should quickly return to where it was. It virtually snaps back to it's resting point. Do this several times. 5-6 If at any time it returns sluggishly then it needs to be oiled. 3 in 1 oil works great.
This takes time. I used a small jewelers screw driver to deliver the oil. As you oil it move the cam back and forth to work the oil to the shaft. Standing the unit on edge after you put the oil in the gap helps the oil get to the shaft.
If it now starts to snap back put the bulb cover back on and try the unit. If after 5-6 movements it still does not snap back each time then the actual motor shaft needs to be oiled as well.
Take the top off. There are several screws and one on the back. All have an arrow marking them. The cover is caught around the lens assembly. You have to be a little bit violent to get it off. After the cover is removed, you have to really look for the upper iris cam. It is under the large multi pin connector with brown wires on the main main display board. There is a small perforated metal cover under this connector.
After bending the cover up you will see the linear motor that drives the iris. There is a small flex cable going to it. You need to oil it's shaft. Use the same procedure to oil it as the cam under the unit. After oiling this shaft the iris should now snap back to rest every time. That's it.
Anonymous
  • 3 Answers
  • Posted on Jan 19, 2009
SOURCE: Kenwood KDC-MP438U "USB ERROR"
IF YOU DID NOT PRESS THE RESET BUTTON NEX TO THE USB PLUG, DO IT. IT WILL REINITIATE THE DEVICE TO THE FACTORY; YOU WILL HAVE TO ADJUST THE CLOCK.
I DID BECAUSE IT WAS WORKING AT FIRST.( PAGE 3 OF THE MANUAL)
CLAUDE
Anonymous
  • Posted on May 31, 2009
SOURCE: goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
How to reset my kenwood xd v323
pl go through the manual which link is attached herewith Kenwood RXD V323 Manuals
1helpful
Menu button on my kenwood rxd-v323 not working what to do i have also lost my remote
Do you feel menu button is working or not compare to other buttons, Menu button it self is problem or sometimes if other buttons are pressed, menu or other button will not function. Good luck..
How to enable eco mode in kenwood rxd-v323
Hello Kamran, the Kenwood rxd-v323, does not have an echo option
Hola Kamran, el Kenwood rxd-v323, no trae opcion de eco
Kenwood RXD V323 Service Manual
1helpful
Cassette belts present in kenwood rxd-v323
Hello Kamran, I sent you the link to download the manuals of your Kenwood RXD-V323, so you can check the numbers of the belts you need
I hope it helps you
Greetings Franco Dosil
Hola Kamran, Te envio el link para que descargues los manuales de tu Kenwood RXD-V323, para que consultes los numeros de parte de las correas que necesitas
Espero te sirva
Saludos Franco Dosil
https://www.manualslib.com/manual/950090/Kenwood-Rxd-V323.html#product-RXD-V323
Download manual
2answers
I want user manual for kenwood rxd-v323
Here is a link that could have that manual you are looking for.
Cant adjust the time o the clock
  1. Select Clock Adjustment item during Menu mode (In Standby mode see below for standby mode explained). Select the "Clock Adjust" display.
  2. Enter Clock adjustment mode. Press and hold the control knob for at least one second. The clock will blink.
  3. Adjusting the clock. Push the control knob towards the left or right to select hours or minutes. To adjust each item turn the control knob or push it towards up or down.
  4. Exit clock adjustment mode. Press the (FNC) button.
  • Turn on the power.
  • When the power is ON, select a source.
  • SRC Select mode 1: PRess the (SRC) button and then turn the Control nob or push it toward left or right.
  • To determine the selected source, press the Control knob.
  • SRC Select mode 2: Pressing this button each time switches between sources.
  • Turner ("Turner"), USB or iPOD ("USB" or "iPod"), CD ("Compact Disc"), Auxiliary input ("AUX"), and Standby ("STANDBY")
  • Press at least 1 second to turn off the power
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
