Dryers Logo
stevenmillar Posted on Mar 27, 2019
My candy grand codenser model number GOC580C won't start but there is heat coming from it and I can start it by switching it on and spinning the drum closing the door and pressing the button
1helpful
2answers
My candy grand o comfort dryer won’t start. It just makes a continuous buzzing noise. Could it be the capicitor? When I spin the rotator it starts up but when it stops it won’t start again. Anyone know...
I don't know what a "candy grand o comfort dryer" is. If it is electric powered, what you are describing sounds possibly like what is called "single phasing". This is where a motor that is supposed to run on 220 - 240 volts is only connected to half of the circuit, or 110 - 120 volts. If this is the case, then it's probably either a blown fuse or a bad connection in the wiring or in a switch. To avoid damage to the unit, I highly recommend that you don't try to run anymore till the problem is corrected, and that you get a licensed electrician to troubleshoot and correct the problem.
The water light full light keeps coming on and the tumble dryer it stops working but the container has very little water in. it's a Candy GOC580C
SOUNDS LIKE A BAD MOISTER SENSOR USUALLY LOCATED INSIDE THE DOOR PANEL AT BOTTOM, LOOKS LIKE 1 LONG LITTLE SILVER THINGYS
My candy dryer is heating but the drum won't turn what can i do
replace drive belt contact manufacturer for agents for parts
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 • Dryers
Hi, I have a candy Grand O GO1682 washing machine and on spin it is making a very loud rumbling noise, So i am assuming this is the drum bearing, But What is the part number, is there more than one, and is...
I HAVE THE SAME PROBLEM, AND A ENGINEER SAID THAT THE BEARINGS HAVE GONE AND THAT IT TAKES 2 PEOPLE TO FIX IT AND THAT THE BEARINGS 7 DRUM COME AS ONE COMPLETE SYSTEM AND WILL ROUGHLY COST ABOUT £200 AND TAKE ABOUT 2 HRS TO FIX. SO IS IT WORTH IT OR BUY ANOTHER ONE INSTEAD.
Candy grand o not spinning when loaded
Kindly replace the motor to solve your problem
My Candy automatic washing machine will not spin
Try the drive belt from motor to the drum it could have stretched a little? The noise you can hear could be the heating element catching the inner drum or something like a wire from a bra came loose in a wash and is trapped between the drums ?
I have a candy AQ 1200, it fills with water then drum turns and s
sounds like m/c is waiting to heat up water but heating element is not working or timer switch not going on to next cycle.
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Top Candy Dryers Experts
vince
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Candy Dryer Expert? Answer questions, earn points and help others
