Question about Panasonic Lands Phones
How to get back the dialed numbers for redialling?
Panasonic KX-T7730
Anonymous
SOURCE:
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Panasonic KX-T7730 Speed Dials - Please Help!
So I guess that means you're not programming SYSTEM speed dial numbers. Those are programmed from the system manager or operator's station. Personal speed dials are 1-0 and are programmed per set.
Carl
Posted on Sep 03, 2009
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Carl
Posted on Nov 09, 2009
Anonymous
SOURCE: kx-t77730
in the left side of phone is a ringer setting key, put it in big bell symbol
Posted on Dec 21, 2009
Anonymous
  • 113 Answers
SOURCE: I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
Posted on Mar 24, 2010
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: KX-T7730 HOW TO REDIAL 10
If your system is a TA-824 or higher and you have Caller ID, you can set a button that will capture the CID of the last calls you have answered on your set. The feature is called Caller-ID Personal and it requires 2 left side buttons on the phone to be preprogrammed for that feature.
Label them CID-S and CID-I. I put them on buttons 11 and 12 (counting from bottom to top) in the S and I order. To do that, press PROGRAM the button and dial 7 STORE for Indicate and 6 STORE for Select. Now, when a call comes in, it will save under the buttons and you can view them with tie I and S buttons and the navigator up and down arrows.
Carl
Posted on Feb 27, 2011
Where is the re-dial?
Hi, Hope this helps.
Making a call using the redial list
The last 5 phone numbers dialed are stored in the redial list.
  1. 1 {REDIAL}
  2. 2 Press {^} or {V} to select the desired number.
  3. 3 phone icon.
I have also inserted a link to the manual below: http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.PDF
Hope i have helped, ALAN
Jun 28, 2011 | Panasonic KX-TG5632 Phone
Panasonic KX-T7730 Corded Phone programmed speed dial numbers not working. will not dial numbers programmed
When the system is installed, you need to make sure that only the lines equipped are in the access plan (program 400 in a TA series box). When you go to the intercom on a phone and dial "9" you should get an outside line every time. If that works, system and personal speed dials include that access code as part of the number. eg my test number is 914197845522 9+1+10 digits.
Carl
Apr 01, 2011 | Panasonic KX-T7730 Corded Phone
How to set speed dial on panasonic kx-t7730
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00.
3. Enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial.
4. Press AUTO DIAL / STORE to save your setting.
5. To go to the next speeddial location press SP-PHONE and follow steps 3 and 4 again.
6. Press PROGRAM to exit program mode.
7. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
Apr 12, 2010 | Panasonic KX-T7730 Corded Phone
How do i delete speed dials on panasonic kx-t7730
since panasonic kx-t7730 does not have a delete option
we can however replace the number to a another number or a dummy number as per the model
KX-TA624 ....PRESS 2 *
KX-TA1232...PRESS 3 0
.... TYPE DESIRED NUMBER(eg: 0000)
AND HANDUP
This would replace the existing number
tell me if this works
Feb 24, 2010 | Panasonic KX-T7730 Corded Phone
Carl
Nov 09, 2009 | Panasonic KX-T7730 Corded Phone
Carl
Sep 02, 2009 | Panasonic KX-T7730 Corded Phone
Resetting the Panasonic KX-T7730
go to menu .... settings.......rest. factory setting..
your security code is 0000 or 1234
try both code one by one.
when u change the code remember the new code.
Jul 28, 2009 | Panasonic KX-T7730 Corded Phone
Conference call when connected to other internal lines
First dial a number,while talking to that person dial another number, after dialing the another number press redial button,than you can talk to another person but the the first line i.e. the the person you are talking at first will have to wait, he will not be able to hear waht you are talking with the another.in order have a conference than again press re-dial button than you will be able to have a conference.....
Jul 21, 2008 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
67 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
