I have a Miele G5775 dishwasher. I just replaced a circulation pump and it slowly leaks at the connection of the pump and the housing that the pump slides into. How do I seal it from leaking?
SOURCE: 2002 chryler sebring is leaking anti freeze
It depends on where the leak is coming from. If the water pump is leaking, it has a hole on the bottom of it. You will see a trail of dried anti freeze coming from the bottom of it, indicating a bad water pump. It's best to dry everything off, crank it up and let it come to operating temp and check for where the leak is coming from. It may just be an old hose or loose clamp.
SOURCE: 1995 Mazda Protege, leaking from the Water Pump seal.
the water is coolant, it is coming from the water pump front seal.
SOURCE: leak between seal plate and pump/strainer housing
The pump seal is leaking and needs replacing and requires removing four 3/8 bolts (9/16) wrench and removing the motor then the diffuser to get to the impeller and seal . A 7/16 wrench holds the rear motor shaft behind the springs and impeller spins off to reveal the seal which has two parts one on the impeller with a spring and one in the seal plate is white ceramic/ porcelan whatever they use. Part number is an SPX1600KA on super pumps and 1500KA wassome above grounds. When replacing do not touch the mating white and black surfaces with your fingers.
SOURCE: dishwasher leaking around the bottom of the door
I had the same problem in 2004, lots of Bosch trained repair techs, calls to Bosch, and the appliance dealer we purchased it from with no answers. Our kitchen cabinet bases were ruined by the flooding that occured. After months of trying to get help I insisted on speaking to a supervisor that told me it was my fault for putting a flexible cutting board on the right side a blocking the vent. I told her that no where in the manual did it mention this issue and none of their trained techs were aware of this flaw in their design. When I asked about getting my cabinets repaired she said that was not an option. When I mentioned possible legal action her response was "good luck with that". Here it is 2009 and they recently called about a possible fire hazard recall for the control panel. The Bosch trained tech that came out to complete the repair knew nothing about the vent/flooding issue.
SOURCE: viking dishwasher leaking!
Hi, ty
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
The pump did not come with the new housing seal and I had to reuse the old one. Put it on caulk to seal the leak. 6 weeks if daily use. So far so good
