SOURCE: Sirius Sportster
Unfortunately this is a fairly common problem in the Sportster, caused by worn contacts in the tuner. Sometimes you can temporarily resolve the problem by wedging a thin piece of cardboard behind the tuner in the cradle, to create a better contact; but eventually it will just wear out again.
SOURCE: power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
SOURCE: Sirius receiver display
I would try and call sirius they might replace to keep your business!!
SOURCE: my sirius sportster ( SP-R2 ) satelite radio
did you try going into the menu and increasing the volume output
SOURCE: My starmate replay is also stuck on the sirius display
I do this repair for the ST2's. I can replace the SID chip and give your radio a new ID that you can activate with Sirius. I am on Ebay and my user
name is rarey57siriusXM. Look me up I also do LCD and scroll wheel
repairs for the Stiletto 10 and 100's. Cost of this repair service is
$24.95 and that includes free priority mail shipping back to you on all
these different repairs. Thanks
http://myworld.ebay.com/rarey57siriusxm
I had the same issue. This is what Sirius calls a "Frozen Unit". There is no bypass, unfortunately, and it must be returned.
I had mine for 3 days and it froze on the Sirius Logo screen when booting up. If you bought the unit from Sirius, you must contact their E-Commerce department. If bought from a retailer, take it back to the store.
Sorry, mate.
