SOURCE: Cant cook in the oven! Gas Rangemaster double oven 110
Sounds like the oven ignitor is weak and not building up enough resistance to get gas flow. I would replace the ignitor.
SOURCE: rangemaster leisure 110
Hi
Just to say we sorted the problem. Simply the bulb was out in the one oven. We replaced this and problem solved.
Carole
SOURCE: gas convertion
stoves have a pressure regulator as the flex line from the house connects to the stove, it's about 2 inches by 3 inches in dimension and it has a knot in the middle and one to the side of it that is to the front of it that second one you can unscrew and put that knot the other way or upside down, that's the position for natural gas, now some regulators do not have it, in that case get one that can do that,or that is for lp and natural gas. then you must close the air a little bit on all the burners the vent is located as the burner meets the valve that supplies gas to the burners. and that vent is part of the burner.
SOURCE: i have a leisure rangemaster 110 double gas oven
the flame safety device need replacing (FFD)... this lets the full gas through when flame is sensed... safety 1st as a gas engineer will be required..
