SOURCE: zanussi washing machine won't start E10, E40 & E50 at times
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
SOURCE: My deskjet 1280 simply Won't turn on.
Hi
A couple of times this has happened to me and it is to do with the access port at the back of the printer ie it has a lock - unlock symbol on it and a circular handle. Make sure that this is firmly in the locked position. Note that it may seem to be in the locked position but often there is a little bit more it will go ... though dont force it so that it breaks ... try unlocking and firmly locking a couple of times, each time testing the on button. Like I said this has worked for me before
Regards
Mark
SOURCE: Neff W4380X is showing error code 01
error code 1 is usually not heating it will progress through rinse as heat is not called for, when moves to heat stage will stop at that point inexpensive part to replace.
SOURCE: the machine says fill watertank. ventilate. the
I emptied watertank and refilled observing float when full.
When I replaced the tank the float sunk to bottom even though the water tank full.
Dismantled float, cleaned, and gently replaced full tank.Squeezed plastic cap to stay fitted and float working again-message"Fill watertank" gone and Machine "READY FOR USE!"
