Televison & Video Logo
Posted on Aug 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic PT 47WX54J. Blue, green and red out of focus. Tried to adjust convergence and now have warped areas on the screen where the red and green don't align.
Anonymous
Level 2:
Champion:
  • Expert 230 Answers
  • Posted on Aug 07, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
230
Questions
0
Helped
56080
Points
423
Replace STK 392-110 with stk 392-150 ( better).Check any resistor around stk ic.
  • Thank you
4helpful
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
4helpful
4answers
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
2helpful
Green convergence will not adjust
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Blue outlines on screen. not a screen burn or convergence problem
I am not familiar with that particular model but most are similar.
It may need the blue focus adjusted. Most tv's have some type of automatic focus. If the blue is out of focus it can "bloom" beyond the red and green. There should be a focus block with 6 adjustments (2 rows of 3) behind the speaker cover. I wouldn't mess with the one labeled screen or block. Adjust very carefully. They are usually in the order Red-Green-Blue with the focus on the bottom row.
1helpful
Convergence On Panasonic PT-47WX54j
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
Panasonic projection tv
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Panasonic hdtv pt-56wx42
  • Screen looks 3D
2helpful
4answers
Sony KP 53v75 blue convergence will not adjust
No, there is no such thing as a convergence box. There is a convergence board but it should only be touched by a qualified tech who knows what he is doing. If you suddenly see an arc of color on one or more sides of the picture, and you cannot correct it with the user menu, it means that one of your convergence IC's has burned out and needs to be replaced. A good tech can replace the IC (and fuses if needed) in-house in about an hour and a half. I charge $150 when I fix a set like that but shops in your area will vary so ask around.
Convergence images?
The blue picture tube of a projection tv is usually the weakest in ability to focus and in most cases loses its focus ablility before the red and green. Connect a cross-hatch generator to the rf inputs of the unit and check to see which areas are most out of convergence. The corners are usually the worst. HD will always bring out the slightest imperfections. If the unit was totally out of convergence, I would have suggested replacing the convergence IC'S.In my experience with rear projection, your problem is normal wear . You could conceivably improve the picture by adjusting the blue focus on the screen focus block. Scrivitron
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
