SOURCE: Ryobi Scroll Saw runs at maximum speed
Unfortunatly the speed controls cannot be repaired, they can only be replaced. You will have to find a Ryobi dealer in your area and get a new speed controler.
SOURCE: Ryobi cordless chain saw leaks oil. Runs fine.
The problem is, that it doesn't require 'movement or inertia', to draw/or pump the oil.
It syphons through, naturally.
The only solution is, to not store it with oil remaining in the reservoir.
That's it I'm afraid.
There is no way, to stop it from drawing oil through, without stopping it from working correctly.
Happy, (& safe;) chopping.
& plz don't give me the thumbs up, thanks :)
SOURCE: Ryobi 18 Volt Cordless Chainsaw needs chain oil?...
you can use a reg bar oil or a lightweight motor oil
SOURCE: how to fix an old RYOBI 18 volt battery won't
take a hammer, and apply force. These batteries dont last forever... but i am serious about the hammer... you may be able to free up whats inside (if you know how a batterey works.)... also apply heat.. try to hit it from all angles than slam it down on the back and leave it sit... than try. I hope this works for you my dewalt batteries over the years have don this, and it works.. but BTW. it wont hold a charge for very long anymore.. the battery is pretty much garbage.
