Tax rate was automatically added up until yesterday evening went to ring in a tow and it wouldn't add it tried to set tax rate as described in manual and it still doesn't add it
SOURCE: How Do You Set The Tax Rate?
Turn the switch to Rate/Set, then click Tax+ then punch the number then turn the switch to ON. You are set for your tax.
SOURCE: how do i use the tax rate & exchange rate once I have figured out how to set it?
i have a CASIO MS-80TV calculator how do i set the peso & tax rate?
SOURCE: How do you set a tax rate?!?!?
1. Switch off the calculator
2. Switch it on again
3. Press and hold the tax button (set %) until the display changes
4. Enter the new tax rate
5. Press the tax button (tax +)
Any problems contact [email protected] - he emailed the solution to me and it has worked.
Pam
SOURCE: Set tax rate for Sharp EL-1701C
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
SOURCE: TRYING TO SET THE TAX RATE ON MY CANON LS-120TS
just press tax till it blinks and then set the tax amount and then press tax button again
