SOURCE: I need a maual for a Yamaha 85 hp outboard motor 1992 model?
Hello nic nic 68,
I know that a autozone will have the manual you are looking for. If you still need assistance please post again and i will gladly help.
Please post what you decide to do and how you do it.
I look forward to your posts.
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
SOURCE: 40 hp mariner outboard 2 stroke oil leak at
without seeing it in front of me its difficult to advise,i had a mercury but it wasnt oil injection so i iam not sure exactly how this injection system works but i should imagine its nothing more than a O ring thats perished or a copper washer needs cleaning with some wet and dry.I bought a new 4stroke mercury in the end because i got fed up with fuel consumption from the 80hp two stroke ,this four stroke 50hp will do about 12 14 nautical miles to roughly 6/7 litres of petrol at about 1200 rpm because iam only a sunday driver and the bumping on the waves makes my back ache unbearable,Well this is the land of fiesta /siesta /manaña --spain .Have a closer look and see where its leaking its only a mechanical pump running off the engine ,so it will have a push rod with some sort of diaphragm that pumps a tinysquirt of oil into the crankcase so it can mix with the incoming fuel ,nothing complicated
