2. Failed fuser lamp(s).
Check continuity of the three upper fuser lamps L2, L3 and L4. Check the operation of the three upper fuser lamps in the Service Mode by following the steps below. Replace failed fuser lamp (p/n A03U M31E 12 for bizhub PRO C5500/C5501/C6500/C6500P/C6501/C6501P/C65hc and p/n A1DU M31E 00 for bizhub PRESS C6000/C7000/C7000P/C70hc/bizhub PRO C6000L).
a. Press Utility/Counter.
b. Press "Stop 00" "Stop 01" to access Service Mode.
c. Press State Confirmation.
d. Press I/O Check Mode.
e. Enter code 45 using the numeric keys.
f. Press Access to enter multi mode 11 (L2).
g. Press the START key. Verify the lamp comes ON.
h. Press the STOP key.
i. Press "C" key to enter another multi mode.
j. Repeat steps 6 through 8 for multi mode 12 (L3) and 14 (L5).
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta Bizhub c350 error code c-0510
I have this code
C0510 Upper fusing roller abnormally low temp
how can I replace the thermistor in the fuser
SOURCE: how to fix error c-1183
This code is for a bin/tray raising or lowering failure in the finisher. This can be caused by either the trays not being fully inserted into the finisher or something stropped the bins from raising or lowering. Check the trays and make sure they are as close to the finisher/fully installed as possible. Then turn off then back on the main power switch (NOT the stand by one on the control panel)
You should see the bins raising and lowering into their home position.
