SOURCE: tv bravia kdl 40v3000 problem turning on
To wayne: The balancer board is in fact available by itself. You can get it at many different parts depots here on the web. I just suffered from a similar problem, on the same tv and it solved my problem perfectly (Stupid 13 blink, blink code...)
The searchable part number is
SSB400WA20. Its referred to as a voltage inverter (for the backlight of the lcd panel.)
Good luck!!!
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
SOURCE: My Sony Bravia has no colour
If the
picture has no color or appear as black and white only, please reset
the picture setting. To reset picture setting please follow the items
below:
If this does not not work, then change the picture board in your TV.
Please rate my solution.
Good luck.
Testimonial: "have colour now when I use my DVD player. but not with my Bell Express Vu PVR. I guess maybe I need a new receiver?"
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
