Cell Phones Logo
Nancy Korb Posted on Mar 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't turn on the phone call option in the Bluetooth menu on mu google2xl
Chan Sun
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 115 Answers
  • Posted on Mar 21, 2019
Chan Sun
Expert
Level 2:
Cheetah:
Answers
115
Questions
0
Helped
16571
Points
197
Try different BT device, or get another caller handfree app, try again.
How is a using a smart blutoothe
Sony Ericsson phones have built-in Bluetooth capabilities which allow them to be connected to a computer or a Bluetooth-enabled accessory such as a headset or speakerphone without using wires. Since Bluetooth does take some power to operate, most Sony phones default to having the Bluetooth powered off to conserve battery power. You can power on the Bluetooth on your phone fairly quickly.
Step 1
Press the "Menu" button on your phone and then select "Settings" from the available options.
Step 2
Select "Connectivity" from the Settings menu, and then select "Bluetooth" from the available options.
Step 3
Select "Turn On" from the Bluetooth menu to power on the Bluetooth on your phone. If you only have a "Power Off" option, then your Bluetooth is already powered on.
How to turn on the bluetooth
Hi, Because you didn't give your phone model I'll give you a generic answer.
Menu to bluetooth
Click on bluetooth (this will turn it on)
Go to options
Click find bluetooth device
Turn on the device you want paired with you phone
The phone should see the device and then press OK when asked
You may have to tweak the instructions to match your phone and devices but that is easy to do, just follow the menu screen directions.
How do i turn my bluetooth on and reieve songs
Turn Bluetooth ON or OFF on BB RIM:
1. From the Home screen, press Menu.
2. Click Options.
3. Click Bluetooth.
4. Press the Menu key.
5. Click Options.
6. Set LED Connection Indicator to On or Off.
7. Press Menu.
8. Click Save.
Using the other phone, or other device, search for the available Bluetooth device in range. The BB should be detected or found. Then, pair the two devices and connect. Once the two devices are connected, select a song from the source device, and find the option to send the song via Bluetooth.
Thank you!
How do I turn off the automatic answering feature on mu Samsung s3500
hello,
1. go to the menu,
2. select the settings,
3. select call settings,
4. you'll see the answer option,
5. turn off the auto answer,
take care
I have a broken screen but the phone still turns on i just need to turn the bluetooth on so i can use switch with my new phone
you can select organizer option from the main menu there you can get option as bluetooth. you can just bluetooth as on and transfer the data to new phone
1helpful
Lost instructions how to pair with my phone
Bluetooth technology is a way to boost your mobility when talking on the go. It similarly provides a wireless network for transferring files and pictures that you have acquired on a mobile device. Enabling and using this function can be beneficial whether for business or for pleasure.
  1. tep 1 Select from the menu "Settings" --> "Connectivity" --> "Bluetooth." This will bring you into the Bluetooth menu function, allowing you to configure your Bluetooth technology. In this menu, you'll find an option to turn Bluetooth on or off. Select "on."
  2. Step 2 Look for devices on the mobile phonemag-glass_10x10.gif that will be compatible with a Bluetooth device. There is a menu option to seek these devices. If a device is listed on the menu, you have the option to pair this device with your mobile phone. To do this you'll need to enter your security password. This is generally created when initially setting up your mobile device.
  3. Step 3 Check for the visibility option. The phone does have an option to either make your bluetooth device visible or invisible to other Bluetooth and mobile devices. It's your decision to remain private or broadcast your signal.
  4. Step 4 Use Bluetooth for data transfer. Once connected, you'll be able to transfer calls to your headset, transfer photos from your cell phone to your computer, transfer photos from your computer to your phone, and transfer files back and forth. Ensure your invisibility when transferring sensitive information to avoid hackers and losing information to other Bluetooth users.
1helpful
Bluetooth turn on
select the menu>settings then press the main key side-wise and go to the connectivity option>first option is bluetooth just select it and u wil hav the option to on or off it.
3helpful
Plantronics bluetooth headset 610
Hi. First the code. Almost every headset uses the code 0000 (that's 4 zeros).
Now the pairing. You didn't say which phone you are using. I'll assume you know how to get into "Options" (if not, please let me know what model you are using and I'll give you more specific instructions.
To connect your headset, start on your phone.
Open "Options"
Open "Bluetooth"
Open menu within Bluetooth.
If not already on, click "Enable Bluetooth"
Open Bluetooth menu again.
Open "Options".
Turn "Discoverable" to "Yes"
Now to your headset.
Start with your headset turned off.
Press and hold down the silver call control button.
After 6-10 seconds, the light will flash blue, then it will flash red, then blue.
Release the buton when you see the red/blue.
Back to your phone.
Again open "Options"
"Bluetooth"
Open the Bluetooth menu.
Click on "Add Device".
Your phone will search for your headset.
If you are prompted for a Passkey, use 0000 (that's 4 zeros).
After a short time, your headset will appear on your phone.
It is now ready to use.
Make sure you go back into Bluetooth Options and change "Discoverable" back to "No".
A tip: If you will not be using your headset for a while, "Disable" Bluetooth to save battery life.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
