Washing Machines Logo
Rick Sanchez Posted on Mar 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My maytag altlantis washer model number MAV7200AWW serial number 2115649AE will not spin the clothes. What may be the issue.
Jim Hicks
Level 3:
Master:
  • Master 661 Answers
  • Posted on Mar 21, 2019
Jim Hicks
Master
Level 3:
Master:
Answers
661
Questions
0
Helped
205577
Points
1952
I don't know. i just repaired a top load with same symptoms.
I found the pin on lid did not quite reach the 'CLOSED SWITCH'. finger on lid was plastic so i had to lift lid and raise pressure switch by wrapping a ribbon of sheet aluminum around it so plastic lid pin could reach it. do not
cheat this safety switch as it shuts off spin so folks won't loose their arm. DO NOT BY PASS THIS SAFETY SWITCH.
5 Related Answers
Anonymous
  • 109 Answers
  • Posted on Mar 30, 2008
SOURCE: Maytag Neptune MAH400AWW
rear tub bearing is going out, must be replaced, causing too much drag. labor intensive repair.
Anonymous
  • 481 Answers
  • Posted on Jul 01, 2008
SOURCE: Maytag model LAT9605AAE serial
make sure all of the legs are adjusted correctly. maytag washers also have to be on a very stable floor. if the floor is not stable or if the legs are not adjusted properly then the machine will shake all over as if they are out of balance.
Anonymous
  • 1028 Answers
  • Posted on Jul 10, 2008
SOURCE: GE Profile washer
suspect gearcase ask for estimate first..could be more than new washer
Anonymous
  • 68 Answers
  • Posted on Jan 17, 2009
SOURCE: Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Anonymous
  • 1304 Answers
  • Posted on Oct 10, 2009
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
100 series clothes washer not spinning
I don't see a question but you may find help at the link below.
If you need to buy parts or diagrams try searspartsdirect.com
Have your model number ready.
maytag washer won spin YouTube
Maytag top load washer MAV7200AWW does not drain water sometimes
this is a very good washer, if you are not getting the water out first check the belt , second check the pump the pulley on the pump should turn freely and no play in it back and forth if you notice play in the pump replace it, next how is the washer drain hose , is it in a standpipe or connected with no air gap, if you do not have an air gap you may not be able to pump the water out plus getting sewer water back in (smells) there are products out there to clean the inside of the tub (tide makes one also afresh)
1helpful
I have a maytag neptune topload washer, & for two days i havent been able to get my clothes to drain & spin, every time i press start, it spins for about 10 seconds & then stops & never...
Can you let me know which model you have…FAV6800A or FAV9800A?
IF it’s the LED display console do you show any unbalance error codes such as dC or uC?
What are the first two digits of you serial number it will be 10,11,12, to 17?
The serial number location;
Handy Links;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Let me know if I can help.....Rich
It does not want to spin without making a lot of noise. What can i do it is only 4 yrs old
If it's a FAV6800A or FAV9800A run a Spin Only cycle with no clothes in
the wash basket. Do you hear noise like metal against metal? If so it could be Outer Tub Bearing noise. Please confirm you model number and first two digits of your Serial Number
Which is your machine? Rich
If it's one of these machine models we will continue
Washer will not spin clothes "dry".
Lgm0923, we're sorry to learn of the experience that you've encountered with your Washer. Have you tried the troubleshooting suggestions on page 5 of your User Guide? The link is below. https://www.whirlpool.com/content/dam/global/documents/200311/owners-manual-3955869-RevB.pdf
If further assistance is needed, please email us your name, address, contact number, model and serial number at [email protected].
We just purchased a Maytag Elite series washer & dryer. We have balanced the washer front side to side, back to front and back side to side. When i wash a load of clothes, the washer literally jumps...
Cawnee:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Maytag® Social Media Relations
Model number AS 200 serial # 251033 Maytage
either a bad pump or a worn or missing belt, lean machine back and check your belts
I have a maytag washier and it is working but it makes a lot of noise -it sounds like jam Model number is MAV2755AWW Serial number is 27422854JT
Your Maytag washer may vibrate or make some noise during normal operation. If vibration and noise are excessive, however, you'll need to troubleshoot the problem. The two main reasons for such an issue are overloading and nonlevel installation. Overloading can be corrected by putting less clothing into the washer before you run a cycle. It can be corrected mid-cycle by removing clothing articles from the washer mid-cycle. It's also very important that you make sure that your washer is located on a firm, completely level surface. Otherwise it may create severe vibration and noise, possibly even enough to damage the machine or nearby items.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
