Question about eMachines Computers & Internet
I have an Emachines desk top that has gone thru a power failure and will not boot up, the fans come on and switch blinks what might be done to correct this prob. ?
    Master:
  • 665 Answers
EMachines were kind of junky when they were new anyway, so I wouldn't consider it to be a great loss. Think of it as an opportunity to upgrade to something better!
Posted on Apr 09, 2019
  • 346 Answers
Hi there. If your desktop has been overheating for any reason you will need to look at buying a new processor (cpu), power supply (if wires have been damaged from heat or voltage spike), or possibly a new motherboard. It would be advisable to have a computer shop look at the internal components of your desktop. Heat or a surge in power can damage the computer hardware. Good luck!
Posted on Mar 20, 2019
  • Dalynn Turner Mar 21, 2019
    I would also like to point out you might need to check the RAM sticks. One could be bad. Be sure when you unplug your Emachine to also hold the power button down for few seconds. Any hardware component could be faulty causing the video not to display.
6ya staff
SOURCE:
Anonymous
  • 110 Answers
SOURCE: EMACHINES W3052 SUTS DOWN AND THEN RESTARTS ON ITS OWN
Emachines power supplies are notorious for being cheap and unreliable. You can pick up a new one that will most likely solve your problem for not too much cash. This one would work fine:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153023
Posted on Feb 17, 2008
Anonymous
  • 63 Answers
SOURCE: wont boot up
try to change your RAM,if same also
try to change your graphic card if u use it...
happy trying..
good luck..
Posted on Apr 17, 2008
Anonymous
  • 4 Answers
SOURCE: Desk top will not start
OPEN RAM SLOT AND CLEAN IT THEN PUT
Posted on Mar 21, 2009
leecom72
Lee Hodgson
  • 4806 Answers
SOURCE: I have fan failure. It has been making a strange
You need to replace the CPU fan as it has failed, I recommend that you refrain from using the computer until you have replaced the fan, this is because it has no way of cooling down and you will be running the risk of blowing the processor and/or the motherboard up.
The CPU fan is located inside the case and is attached to the motherboard on top of the processor.
Regards.
Posted on Jul 10, 2009
IQUIT
  • 3940 Answers
SOURCE: dell dimension e310 desk top will not power on
If the POWER Button on the TOWER is blinking AMBER (Yellow) then the most likely failure point is the POWER SUPPLY in the Tower.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817226001
Posted on Dec 21, 2009
Dell opiplex GX620
You need to enter your pre-Windows boot startup screen and set (at a minimum) the date and time. All the data that your battery powered is now gone, so you need to re-configure your BIOS.
Entering System Setup:
1. Turn on (or restart) your computer.
2. When the blue DELL logo appears, press <F2> immediately.
Aug 23, 2017 | Computers & Internet
My E Machines Desk top model #EL1200 boot up how do I get it to last known good configuration?
when you power the machine press f8 from their select from the boot menu
Sep 17, 2013 | eMachines T5274 Desktop PC
Emachine troubleshooting
This is typically caused by a power supply failure. Failing power supplies can have enough power to turn on lights and fans but not enough to start the computer. The power supply does not store any data so replacing it is a low risk and low cost effort. It is a very well documented process so search the Internet for "replace power supply" for more details. I hope this helps. Good luck!
Apr 29, 2013 | eMachines T6534 PC Desktop
How do you do a cold boot on a dell desk top model Inspiron 530? The computer will not boot up
Hmmm....you press the power button on the front of the case. I am not sure what you need exactly. If the computer has had a different power supply installed there could also be a power switch on the back of the case.
If everything is plugged in correctly and you don't hear fans or hard drive sounds, you most likely need a new power supply.
Jan 18, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
I have an eMachines T2200 The power supply started making noise and I shut the system off. The next time I tried to boot up nothing happens. I replaced the power suppy and when I turn it on the cd and dvd...
I would check to see if power is getting to your hard drive, Make sure the white molex's are plugged in.
E-Machines are, unfortunately the worst machines out there. They're up there with Compaq.
You're not going to like what I say but I'd urge you to buy a new one. Chances are it will take an arm and a
leg to fix what your using and for a little bit more money you can have a really nice one for 500 dollars
or less.
Dec 31, 2010 | E-Machines eMachines Desktop PC
Dell dimension e310 desk top will not power on
Dec 21, 2009 | Dell Dimension E310 PC Desktop
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
Emachine model T3418 problem
make sure the ram is setup correctely or is right ram
Sep 28, 2008 | E-Machines eMachines Desktop PC
My computer
try their support page at http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T3410 and download the latest drivers
Apr 21, 2008 | E-Machines eMachines Desktop PC
Well, you are right the power supply is good. But the power isn't enough to support your system. My advise, you have to change your power supply to "real power type". The price is more than the normal type even if it is the sama rating.
Feb 17, 2008 | Computers & Internet
Computers & Internet Logo
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
