Boating Logo
Sam Dyson Posted on Mar 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2000 50hp 2 stroke outboard. Why doesn't it start?
Less than 100 hrs. Been 3 yrs since in the water
Steve P
Level 3:
  • Yamaha Master 3,912 Answers
  • Posted on Nov 12, 2021
Steve P
Yamaha Master
Level 3:
Answers
3912
Questions
5
Helped
1305739
Points
15904
The carburetors are in desperate need of some PROFESSIONAL attention. They all stop up after sitting for that long.
5 Related Answers
Anonymous
  • 97 Answers
  • Posted on Mar 17, 2009
SOURCE: oil light blinking
Screw a test gage in the engine where the electric sending unit is. Check to see what the pressure is cold and after it is warmed up. It may be a bad sender.
Anonymous
  • 710 Answers
  • Posted on Apr 27, 2009
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Dennis Sharp
  • 154 Answers
  • Posted on Aug 03, 2009
SOURCE: Yamaha 50hp outboard
its working fine
al at yahoo
  • 115 Answers
  • Posted on Sep 03, 2009
SOURCE: 2003 yamaha 50hp 4 stroke, won't start
sounds like you are going to have to pull carbs off and clean jets also check tank and line for debries
Anonymous
  • 18 Answers
  • Posted on Sep 21, 2009
SOURCE: yamaha outboard starting
New plugs and service
Hard starting on Yamaha 130 2 stroke. Always starts easily with ether. Choke works well.
This can have some reasons:
1 clogged carburettors. Too less fuel means a hard start.
2 Worn spark plugs
3 Loss of compression... On a 2-stroke, measuring compression is not an exact science. Have throttle wide open. No spark plugs, check compression on all cylinders. They should be all within 1bar from eachother...
2004 9.9 Yamaha 2 stroke. Previous owner used 50 to 1, motor sticker says 100 to 1 mix. I ran it with his gas mix with only a puff of smoke when starting. What mix should I use?
100 to 1 is TOO lean...If you like your motor and your money,, stick with at least 50:1.. I would prefer 32:1 and if you start fouling plugs too often.. drop back to 40:1...
Too much experience with two cycle engines to risk running something at 100:1.. rebuilding one of these outboards is $$$$$$.. a spark plug or two is less than $10...
Jul 25, 2017 • Garden
1helpful
For a yamaha outboard motor 2 stroke , how much oil would be added to 12 litres of fuel
50 litres petrol:1 litre Outboard TCW3 OIl
100litres petrol:1 litre Outboard TCW3
@ 50:1 You Would Put 240Mls Oil In 12 Litres Petrol
@ 100:1 You Woul Put 120Mls Oil In 12 Litres Petrol
Mar 12, 2013 • Boating
2helpful
Free Mercury Outboard ONLY, 2-40HP 1965-1989 Repair Manual 1-2 Cylinder, 2 Stroke
I have a problem with my 2 stroke 20hp mercury 1989,when I run 10-90% throttle it's works fine but when in 100% its only runs in 90% and doesn't sound normal like it's not burning right.
About 4 yrs old 90? hp 4 stroke outboard runs
ignition timing may be off slightly.
Mar 12, 2010 • Boating
I have a 1993 2 stroke 40 hp mercury outboard motor and it seems that whenever you start it you need to use the choke, even when it's been running for some time and warm. Is that normal for these motors?...
Use it .It is a common thing with 2 strokes.Outboards have water in them and cool down quicker than say a 2 stroke motorbike. They have no water and keep the heat in the engine longer.If it runs well,,don't spend the money.All the choke does is gives the motor a slightly richer air/fuel mix at startup.It cannot hurt the motor.Hope this helps
Jan 05, 2010 • Boating
Top Yamaha Boating Experts
neil
Stan Ford
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
