SOURCE: my cd player on the
did you try with original CDs or burned CD, if you are the message error1 with all CD your laser lens is deficient and you have to try first with a clean up CD, if it's already the same problem after you have to go to toyota dealer to fix your CD player
I hope this helps
Please rate accordingly
Thank You
sserpentio
SOURCE: I have a Pinnacle 27
have no idea what the code means but i would hazard a guess and say the heater circuit isnt working ,take it apart and try a volt meter across the heater element
ERR
1 - Motor Movement
ERR1
indicates a speed issue. In this case, the motor speed as reported
from the optic sensor differs
from
the speed setting.
Analysis:
Optic sensor signal issue -- Either the optic sensor signal is not
right, or it is read incorrectly, or
the
signal is not reaching the display.
Clean the sensor, test for open or faulty, tight the connector very well,adjust it, see the diagram attached.
God bless you
