The problem may be the SD card if it's am micro or more than 32 GB it is incompatible with the camera
here is the note from the manual for pixpro AZ421
A standard SD memory card is not included in the camera packaging and needs to be purchased separately. This camera takes a standard (SD/SDHC) memory card. We recommend using a name brand memory card that is Class 4 or higher and has a capacity of 4GB to 32GB. The camera is not compatible with Micro SD, Ultra, Ultra Plus, Extreme, XC, or adapters for any of these other memory cards.
SOURCE: Won't format new memory card
Your camera is not SDHC compatible. It will only support standard SD cards. Sorry.
I hope this helps.
SOURCE: Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
SOURCE: I cannot format my brand new memory card in my Kodak Easyshare.
Believe the 4 GB card is too large for this camera and internal camera software was not designed to format or manage so much memory.. try a fast SD under 2 GB.
SOURCE: Kodak Z740 camera sd card formatting problem
Remove the card...turn on the camera and go into the menu...find "reset"...follow the on-screen instructions. Then try to format the card again.
SOURCE: kodak cx7530 camera refuses to
Your camera was not built to take the new SDHC cards. You can only use SD cards up to 2GB.
