Question about Proscan Televison & Video
Factory reset proscan PLT8031
Go into set up and reset to factory
Reset my proscan notebook plt1035
I cannot find that model number is it a tablet or is it running windows?
if tablet
How to reset Proscan PLT722 when you forgot your password or unlock pattern. How to remove unlock pattern on your Proscan PLT722 android tablet
To reset this tablet is a little bit tricky, because there are no physical Volume keys on the device, but we have a "hidden" RESET hole (on the side of the tablet) and using this we can easily do a factory reset on the tablet to remove the password and get access to it.
Using the Hard Reset (Factory Reset)
If you want to restore your Proscan Android tablet to its original condition, use a Hard Reset (Factory Reset) to initialize it.
1. Turn the power off.
2. Find the tiniest RESET hole on the side of the tablet next to the micro USB charger port and use a paper clip or similar tool to click it, press gently the RESET button in the hole. While you are pressing the reset button press and hold the Power button also until the Proscan logo comes up and the Android robot is displaying on the screen. (Note this is not the RESET hole on the back of the device.)
3. Release the Power and the reset button.
4. To get into the Android recovery menu you have to click it push it down again the tiny little RESET button in the hole and the POWER button together. Keep pushing the two buttons until the recovery menu displayed.
5. To highlight the options use the paper clip and press the RESET button to move down the highlighter bar until you get to Wipe data / Factory Reset. Press the POWER key to get in the next menu.
6. Move the bar again using the reset button and highlight Yes -- delete all data and press the POWER button.
WARNING
If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to backup any important data before performing a Hard Reset.
Proscan PLT722 soft reset or restart the device when it is frozen If device is hanging, use a small pin or paper clip to press Reset hole on the back of the device, it will forced shut down and the device will power on again.
Proscan PLT722 factory reset from the menu Factory data reset - Reset your settings to the factory default values and delete all your data. If you reset the tablet this way, you are prompted to re-enter the same information as when you first started your Android tablet.
Go to Settings > Backup & reset > Factory data reset > Reset Tablet and confirm
All data will be deleted!
Check the software version on your tablet: Settings > About tablet> System updates > Check now.
NOTE: Your personal data from internal phone storage - including information about your Google account and any other accounts, your system/application data and settings, any downloaded applications and your DRM licence - might be lost in the process of updating your phone's software. Therefore, it is always recommended to backup your personal data before updating your phone's software.
Jan 23, 2018 | Tablets & eReaders
Factory reset
Factory reset Proscan PLT 70330 use power and volume buttons to reset.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Factory Reset on Proscan PLT7223G or Tablet
How to reset proscan tablet model PLT7033D to factory setting its locked
want to reset my PIN on my Proscan PLT7033D
Mar 23, 2016 | Cell Phones
How to reset passeword
you have to go into setting and set to manufactures settings. look for pin hole that states reset
now if you have a password already and you setup the password already that trying to bypass the password setting you will need the password in order to get to those setting i think.
you could go to website for the manufactures look up lost pass word bypass, or FAQ section, or if technical support can help you if you done all this already .
Mar 25, 2015 | Proscan PLT7223G-K 7in Android 4GB Tablet...
How do I reset my proscan tv set modle number PLDED399A back to factory setting with my remote
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 26, 2015 | Proscan Televison & Video
Proscan 8 inch tablet with android 4.1 jelly bean
Sorry, I have no solution to offer. I am in the same situation and resets aren't working. Wondering if OS is deleted and if so, how to reinstall. So frustrating!
Feb 28, 2014 | Proscan 8 4GB Android 4.1 Tablet
I am stuck on the boot up screen and wont let me reset
Pull battery. or
search for cmd.com
execute cmd.com
type in " shutdown /s " to shutdown the computer at command prompt
type in " shutdown /r " to reboot the computer at command prompt
Jan 21, 2014 | Proscan Recertified - PLT8031 4GB NAND...
I forgot my pass word to my proscan plt8031 tablet
This is everything you need to know to root/unlock/factory reset your Proscan 8" Tablet a.k.a. PLT8031.
First thing you will need to do is charge up your device, download the software needed to your desktop or some other easily accessable folder. Now this is the part that took nearly 3 days to figure out in order for the program to recognize and load an image to it you have to put the device in "recovery mode". You might ask well how do I do this, as every forum out there just says put in recovery mode and it will work, BUT HOW you still ask. The internet won\'t tell you, the company won\'t tell you, hell even other people on forums won\'t tell you. But alas I shall.
RECOVERY MODE Proscan PLT8031
Simply plug in your usb cable to your computer, then while holding your menu button, to clairify as I don\'t know the exact name of the button, it\'s the one to the left of the home button. plug in the usb cord to the device while still holding that button. Do not let go of the button until you see that windows has detected your hardware and is looking for a driver.
FYI windows usually will not find a driver, I have included links to the drivers you will need.Now if your at all used to device manager you should know how to point it to the driver you need. It will be called "rockusb.inf".
Once this is installed then open and run "RKBatchToolv1.4" as administrator. You then need to click the three dots in the top right to locate and load the "update.img" file. Make sure at this point that your device is recognized with a "green square" near the bottom of the window.
If all that checks out click the upgrade/restore button. To be clear it\'s one or the other, not both, technically didn\'t see a difference between them. This process will then start and will take between 5 to 10 minutes. DO NOT TOUCH ANYTHING. if you unplug your device too soon you will have a nice paper weight instead of a tablet. Wait untill it is completely booted into the setup your android device screen before closing the rkbatchtool and safely disconnecting the device.
Congrats on your newly rooted/recovered plt8031 tablet.
29RockUSB Driver - http://uploading.com/2ca29934/29Rockusb-zip
http://www.generalfiles.com/download/gs5a611f4bhci0/29Rockusb.zip.html
http://rapidlibrary.com/files/29rockusb-zip_ulcqxffyzwieon.html
If none of these work for you just google "29RockUSB" without quotes.
Firmware (update.img) - http://www.proscanvideo.com/tech-help/PLT8031.asp
RKBatchToolv1.4 - http://www.filecrop.com/RKBatchTool-1.4.rar.html
http://www.x-drivers.com/catalog/flash/tablets/companies/fuzhou_rockchips_electronics/models/rk_batch_tool/27575.html
Dec 06, 2012 | Tablets & eReaders
Televison & Video Logo
149 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
