Question about Proscan Televison & Video
I have a PROSCAN PLT9650G That has not been in use and now I cannot recall the password. Any hope?
See if you can factory reset
3 Suggested Answers
6ya staff
SOURCE:
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Proscan Tablet password
Take it back or call customer support for the unit.
Posted on Nov 05, 2012
emissionwiz
Marvin
  • 85222 Answers
SOURCE: Forgot my password to get into my proscan tablet plt8967-btk and want to hard factory reset it, how do i do that? Please help.
Contact the manufacturer support site.
Posted on May 17, 2016
Can't remember my password and need it to reset but I push the reset and it doesn't do anything model number PLT7223G
https://www.ifixit.com/Device/ProScan_PLT7223G
ProScan PLT9606g Troubleshooting
Web link above for a different ProScan model states:
"There may be an issue with your software that may be solved with a factory reset. Use a paper clip and insert it into the reset button hole and hold the power button at the same time for 10 seconds. The screen will turn blue and the android icon will pop up with an options menu. Scroll down using the volume button to the "wipe data/factory reset," then select it by using the power button.
Note: This will clear all user data from your ProScan. Be sure to back up important data before performing a factory reset."
Feb 11, 2018 | The Computers & Internet
My Proscan PLT9650G turns on but all that is on the screen, is the word PROSCAN fading in and out. How do I fix this? Thanks
Connect a device to it such as a DVD player and the TV s input source.First I would unplug the tv wait about 15 secs and plug it back in
Feb 06, 2018 | Proscan Televison & Video
Reset my proscan notebook plt1035
I cannot find that model number is it a tablet or is it running windows?
if tablet
How to reset Proscan PLT722 when you forgot your password or unlock pattern. How to remove unlock pattern on your Proscan PLT722 android tablet
To reset this tablet is a little bit tricky, because there are no physical Volume keys on the device, but we have a "hidden" RESET hole (on the side of the tablet) and using this we can easily do a factory reset on the tablet to remove the password and get access to it.
Using the Hard Reset (Factory Reset)
If you want to restore your Proscan Android tablet to its original condition, use a Hard Reset (Factory Reset) to initialize it.
1. Turn the power off.
2. Find the tiniest RESET hole on the side of the tablet next to the micro USB charger port and use a paper clip or similar tool to click it, press gently the RESET button in the hole. While you are pressing the reset button press and hold the Power button also until the Proscan logo comes up and the Android robot is displaying on the screen. (Note this is not the RESET hole on the back of the device.)
3. Release the Power and the reset button.
4. To get into the Android recovery menu you have to click it push it down again the tiny little RESET button in the hole and the POWER button together. Keep pushing the two buttons until the recovery menu displayed.
5. To highlight the options use the paper clip and press the RESET button to move down the highlighter bar until you get to Wipe data / Factory Reset. Press the POWER key to get in the next menu.
6. Move the bar again using the reset button and highlight Yes -- delete all data and press the POWER button.
WARNING
If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to backup any important data before performing a Hard Reset.
Proscan PLT722 soft reset or restart the device when it is frozen If device is hanging, use a small pin or paper clip to press Reset hole on the back of the device, it will forced shut down and the device will power on again.
Proscan PLT722 factory reset from the menu Factory data reset - Reset your settings to the factory default values and delete all your data. If you reset the tablet this way, you are prompted to re-enter the same information as when you first started your Android tablet.
Go to Settings > Backup & reset > Factory data reset > Reset Tablet and confirm
All data will be deleted!
Check the software version on your tablet: Settings > About tablet> System updates > Check now.
NOTE: Your personal data from internal phone storage - including information about your Google account and any other accounts, your system/application data and settings, any downloaded applications and your DRM licence - might be lost in the process of updating your phone's software. Therefore, it is always recommended to backup your personal data before updating your phone's software.
Jan 23, 2018 | Tablets & eReaders
Factory reset
Factory reset Proscan PLT 70330 use power and volume buttons to reset.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Factory Reset on Proscan PLT7223G or Tablet
How to reset proscan tablet model PLT7033D to factory setting its locked
want to reset my PIN on my Proscan PLT7033D
Mar 23, 2016 | Cell Phones
How to reset passeword
you have to go into setting and set to manufactures settings. look for pin hole that states reset
now if you have a password already and you setup the password already that trying to bypass the password setting you will need the password in order to get to those setting i think.
you could go to website for the manufactures look up lost pass word bypass, or FAQ section, or if technical support can help you if you done all this already .
Mar 25, 2015 | Proscan PLT7223G-K 7in Android 4GB Tablet...
How do I reset my factory settings on my Proscan Tablet PLT7810K? I forgot the screen lock password.
I'm not an expert on this particular machine but please try this method:
  1. Press Power button for 2-3 seconds and select Power off.
  2. Press and HOLD the Volume Up button.
  3. Press Power button and release it. Still hold Volume Up button.
  4. When you see the Android screen, release all buttons.
  5. Press both Volume Up and Power buttons for 2 seconds.
  6. You should then see a blue menu. Use Volume Down to select wipe data / factory reset. Press Power to select.
  7. Use Volume Down to select Yes - Delete data. Press Power to reset
  8. Select Reboot system now. Press Power to reboot.
  9. Setup your tablet again and use it as a new tablet.
I hope this helps - Good Luck.
Aug 25, 2014 | Proscan 8" Tablet with 4GB Memory
How to unlock proscan android tablet plt8015-k-b
To perform a factory reset, you will need to do the following: -turn of the tablet -press the following and hold: power button reset hole -hold until you see android logo screen -poke the reset hole to navigate to `wipe data` or `factory reset` -select using the power button -select delete all user data -restart the device -choose restart/reboot after reset This procedure will delete all apps and data on your table
Jun 30, 2014 | Proscan Recertified - PLT7035 4GB NAND...
How do i unlock a proscan plt8816k if i dont remeber the email and password?
Your problem doesn't make sense. You cannot try the password too often. Try a factory/hard reset.
Google search "reset android tablet"
May 10, 2014 | Proscan Recertified - PLT7035 4GB NAND...
Televison & Video Logo
63 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
