SOURCE: Error Code C2500 on a Kyocera KM-2530
a C2500 error code relates to the paper feed area.
It indicates either a faulty paper feed motor, loose plug for the motor or lubrication problem in the feed area.
Hope this helps.
SOURCE: kyocera 5050 error code 2202
This is an error is indicating a connection error when using the send feature. 2101, 2102, 2103, 2201, 2202, 2203, 3101: The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name correctly. 2204: The E-mail size exceeds the acceptable send data capacity. Decrease the size or resolution of the scanned data to be transmitted and resend the E-mail. 5101, 5102, 5103, 5104, 7102, 720f: Turn the main power switch off and back on. If this error occurs several times, make a note of the displayed error code and contact your service representative.(Refer to the corrective action for the error message " An error has occurred.") 9181: The scanned original exceeds the acceptable number of pages of 999. Send the ecess pages separately. Hope this is helpful, Shawn
Below I have provided some information or for more information download the users guide from the manufatcures website using this link. http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=16088&rid=16313
SOURCE: I do I clear error code c4200 in kyocera 5050
Error Code KM4050 with 4200 error code - CopyTechNet.com
www.copytechnet.com > ... > Kyocera Mita, Copystar
Jul 7, 2010 - 10 posts - ?7 authors
I guess that you already know that the C4200 is a beam detect error, and the manual ... Hi Ya, heres a bulletin for km-6030/8030 on the code C4200. ... That it shows up on the corner, it means that you must clean the laser. ... Got a KM5050, machine was FILTHY, dust,dirt everywhere. tried to phone fix the ...
Error code c5300
Apr 28, 2014
Error Code KM5050 C3300
Sep 19, 2012
Kyocera KM-4050 C6400 error codes
Jul 9, 2008
KM5050 error code CFB31. Not in manual
May 5, 2008
More results from www.copytechnet.com
Error Codes > Kyocera-Mita > KM5050 > Code C4200
www.printcopy.info/?l=en...Kyocera...KM5050&code=C4200
