Ex: a show that is advertised to air at 8:00 pm CST displays on the guide at 11:00 pm CST. How can this be fixed. Not all channels are off, only a few.
SOURCE: Zen Microphoto MTP drivers not installing, stuck in loop
Make sure you have media player 11
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
Download recovery tool off creative's website.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
SOURCE: Military Time
Press the "function" button for a couple of seconds. The display will indicate 12hrs or 24hrs.
Use the minute or hour to change the setting for 12hrs and you'll have normal time again.
I hope this helps!
SOURCE: change the time setting from 24 hour to 12 hour AM PM
Check this
Go to start>settings
Go to the system tab and the regional settings icon
Go to the time tab and it should be hh:mm:ss tt for 24 hour clock
Let me know how that works out for you
SOURCE: Digital channel signal blue screen only
Press the "INPUT" button and make sure "TV" is highlighted.
SOURCE: iluv iMM153 please describe how I change the time from 24 hour
i have the exact same problem, i the picture of the product, it says pm on the side of the display, and its can say pm ont he display !!
To Set the Current Time: Press the HOUR button as many times as necessary to advance the display the correct time. Note, the time can only be set in 30 minute intervals. The LED display will display the hour (1-12) and on the half hour a light will illuminate in the upper right corner, next to the number 30. To change from AM to PM toggle 24 times, a dot will illuminate in the lower right corner of the display next to the letters PM.
To Program the Timer: Press the PROGRAM button once, the letter P will flash. Press the HOUR button to set the ON time. Press the HOUR button to set the ON time. Press the PROGRAM button again, the letter E will flash. Press the HOUR button to set the OFF time. Press the PROGRAM button to exit program setting mode. Press the HOUR button to review the ON/OFF setting.To Connect/Operate the Timer: Plug device in to the timer and turn the device on.To Revise the ON/OFF Setting: Unplug the timer and plug it back in. Repeat the programming steps above.To Override the Timer: Press the PROGRAM button if you want the device to turn on before the preset time, but note the device will turn off at the preset time. For example, if the preset ON/OFF period is 3 pm - 4 pm, users can manually press PROGRAM to turn the device on at 2 PM, the timer will keep running until the preset off time at 4 pm.Suitable for use with outdoor appliances. Raintight when mounted vertically with the receptacle facing downward. Use a three-conductor GFCI protected outlet. Do not immerse in water. DO NOT EXCEED RATED CAPACITY. Not for permanent installation. Do not install or use this product for more than a 90-day period per year.
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
