Question about Pentax Cameras
How can I fix a stuck shutter button on Pentax zoom 105 R camera
    Top Expert:
  • Pentax Master
  • 29,792 Answers
You can't. Camera need professional service. Google the manual, some cameras have a lock to keep the shutter open, press down and turn the the right to lock.
Posted on Mar 18, 2019
6ya staff
SOURCE:
Anonymous
  • 277 Answers
SOURCE: shutter button repair
hi it depends on where it broke and if...(the button) if it just fell then u can just take the new button a shove it in untill theres a CLICK if its broke then u will need to pull out the rest and then shove it in DO NOT TRY TO OPEN THE CAMREA IF U DONT KNOW HOW!! you will brake the pins inside when u will and then it will cost u as a new cam good luck windman
Posted on Feb 14, 2006
t00nz
CameraR
  • 4738 Answers
SOURCE: Auto is stuck on and I can't zoom in or out or review pictures - shutter button stuck also
Being very careful, follow this pictorial disassembly (it's in Estonian, but just follow the pictures). Don't go any further than popping the top off the camera! Look for anything obviously broken off near the vicinity of the shutter button, or looking very different than what's in the pictorial. Keep in mind it's amazing what you can do with a little glue and scrap pieces of plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
Also, pay attention to the following post as there is some potential for electrical shock:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Posted on Dec 08, 2007
pishta68
Steven Wander
  • 594 Answers
SOURCE: shutter button stuck
Some have used compressed air, blown directly into the button. this should dislodge anything that is holding the button down. Also check and see if the button is cocked in the body, you can pry it back into position and it should pop back up. It is a 2 position switch, first detent is to hold focus and bottom out is shutter release
Posted on May 13, 2008
Anonymous
  • 58 Answers
SOURCE: Pentax ME Super Shutter and Rapid Wind Button won't release
Common fault due to perished rubber parts. Can be usually be repaired, but do not try to force the camera, that may cause damage which can not.
Go to http:/www.mypentax.com for information on how to service this yourself. The author can also advise by mail, and can service these cameras too.
Posted on Jan 21, 2009
Anonymous
  • 667 Answers
SOURCE: I have an old Asahi Pentax, release lever and shutter are stuck.
The Pentax is a easy fix, maybe.. If you feel comfortable removing the bottom cover, then remove the 3 cross point screws. The battery, if installed will be loose. Looking at the bottom section of the camera, locate the tripod socket. On on side is the battery compartment, the other an L shaped lever. Under the L shaped lever is a brass plate with a slot in it. In that slot is another lever that has a spring going through the end eyelet. Move that lever toward the front of the camera until it latches on the L shaped lever above. Then try the release.
The first thing to try on the X700 is fresh batteries. Clean the battery cap and contacts with a pencil eraser.
Posted on Jan 04, 2010
Mirror is locked open
Unless you have experience repairing cameras, this is not a DIY fix. Take your camera to a reputable camera shop and have a trained professional look at it.
Feb 03, 2012 | Pentax ME Super 35mm SLR Camera
When i take pictures on my pentax optio s10 the pictures are coming out black but the lcd screen is working, is there anything i can do to fix this?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 04, 2011 | Pentax Optio S10 Digital Camera
Plastic shutter button broke. Can release shutter by pushing in the middle but button is gone includeing screw int piece for shutter release. Is this an easy fix?
The only easy fix is to glue with a super glue with the broken part or parts. If this is lost then you need to fabricate a similar type knob to be glued into the slot making sure that glue does no overflow and get the whole shaft stuck.
other wise the original can be sourced or replaced from a worn out/discarded camera or consult the Pentax service for estimation.. to restore it originally.
Jan 25, 2011 | Pentax ME Super 35mm SLR Camera
The shutter on my Pentax zx-50 SLR is stuck in the open postion. I can't see anything through the view finder nor will it focus automatically. However, it will advance the film upon taking a snapshot and...
if its just a sticky mirror you could try to very genteely flip it down again but if the shutter is jamed in its sliders it could need to go to a camera shop to get it "fully serviced!" also check its not just the shutter lock button stuck in, or the shutter is locked open,
Nov 28, 2010 | Pentax ZX-50 35mm SLR Camera
On the lcd it shows "E" "E 9" and I do not know what this means and the camera will not work. What needs to be done
This question has been answered repeatedly. Pentax error codes are mostly for camera repair technician diagnosis and most of the time mean the camera is broken and needs professional servicing. Some Pentax Error Codes:
E: "E" often indicates a film jam. This code can appear when the film is inserted incorrectly, when the batteries are changed in the middle of a roll of film, if you are using defective film, etc. If "E" appears in your camera's information display, try to rewind your film manually (see your user's guide for instructions on how to activate your mid-roll rewind function), and try a different roll. If this problem keeps occurring, you might need to send the camera to us for repair.
E3, E7, E37: These codes often signal a problem with your shutter mechanism.
E9, E93-E97: These codes may indicate a problem with your zoom lens.
H0-H9: These H codes can also identify a problem with your camera's shutter.
U1-U9: These U codes may also indicate a problem with your camera's zoom lens.
These codes are standard for both Digital and film cameras.
Please rate our helpfulness to keep the service viable++++Thanks for using FIXYA
Sep 22, 2009 | Pentax Zoom 105-R Film Camera
Problems with camera. Help please.
THE CAMERA ZOOMED OUT COMPLETELY AND WHEN I SWITCHED OFF IT REMAINS AS IT IS , AFTER PUTTING BATTERY & ROLL IT SHOWING ( f 1 ) & AFTER SOMTIME ( f 2 ) AND AGAIN IT WILL SHOWING ( f 1 ) ON INDICATOR.
Nov 08, 2007 | Pentax IQZoom 200 35mm Point and Shoot...
Blurry pictures with Pentax K1000
It may be the equipment or it may be the way you are holding / taking the picture.
Here are suggestions on how to take better zoom lens pictures (this also applies to any camera) before you start diving into the equipment.
1) Use the fastest shutter speed possible. This reduces the amount of time of exposure, this limiting the amount of motion blur that can happen.
2) Don't hold the camera by hand. Either use a tri-pod or rest the camera on something stable, like a wall, rock, bench, etc. This makes it less likely that the camera will move when you are taking the picture, thus reducing motion blurr in the image.
3) If you have to hold the camera by hand, hold the zoom lens with your left hand (because it is more towards the center of gravity than the camera is) & try to slow your breathing & take the picture between heart beats.
4) Also, another thing that helps is to use a remote shutter release (such as that rubber bulb or plunger attached to the shutter release). I would also say using the self-timer would help, but the K1000 doesn't have that. This is so the camera doesn't shake from you pushing the shutter release button.
5) Make sure the lens is clean! Even get one of those lens pens from your local camera shop.
If you have tried all (or most of these) then its time to start looking at your equipment, such as . . . is your shutter getting stuck when exposing, thus lengthening the exposure and making for a blurring shot or do you need glasses? <grin -- which is why I find it really difficult to use manual focus equipement now, because my eye sight is really bad!>
Take care & Happy Imaging!
Glen
Sep 06, 2007 | Pentax K100D Super Digital SLR Camera
Pentax MX Mirror Stuck In Up Position
This is a result of the linkage from the shutter release button being out of adjustment. It is a mechanical fault that can be repaired very easily.
Aug 14, 2007 | Pentax MX 35mm SLR Camera
What does HI or H1 mean?
This is a zoom error code - the flexible circuit going to the shutter in the barrel is probably worn out. It'll have to go to a repair shop.
Nov 27, 2006 | Pentax IQZoom EZY-R 35mm Point and Shoot...
Cameras Logo
104 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
