Hello Francesco, I sent you the link to the service manual of your Kenwood XD-500, so that you follow the steps to get to the CD changer
I hope the information is usefull
Greetings Franco Dosil
Hola Francesco, te env?o el link del manual de servicio de tu Kenwood XD-500, para que sigas los pasos para llegar al cambiador de CD
espero te sirva la informacion
Saludos Franco Dosil
https://data2.manualslib.com/pdf3/73/7207/720696-kenwood/rdx500.pdf?d49de5368b8f22b833b01cd689435890&take=binary https://www.electronica-pt.com/esquema/audio/kenwood-audio/kenwood-rxd-500-3259
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=mine&fml=0&brd=0&p=2&thid=27262670#
SOURCE: No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
SOURCE: I have a kenwood krc-x957
Code entry on a Kenwood KRC-X957:
1. press the MENU button till the word "MENU" appears on the display;
2. Press the >> button a couple of times till the word "Security" is displayed;
3. Press either AM or FM till "ENTER" is displayed;
4. Wait till "ENTER" changes to "CODE";
5. Press preset button and enter your "Security Code";
6. Press the DISP button till "RE-ENTER" is displayed;
7. Wait till "RE-ENTER" changes to "CODE";
8. Press preset button and enter your "Security Code" again;
9. Press the DISP button till "APPROVED" is displayed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: Code for Kenwood RC 500 Car Stereo
GO TO A STEREO REPAIR SHOP, SOME CAN RESET OR USE FACTORY MASTER CODE TO UNLOCK
SOURCE: CD Changer connector of KENWOOD GX-608EF2B
aye have the same system for my car a subaru, but the release button is missing and need a new one?
