Bose Wave Radio, you can use any Bluetooth Dongle, Amazon ™ is your best bet to get these, I've been using the Ti TaoTronics model number TT-BR06 Bluetooth Dongle, these are extremely great, especially the Battery life and your able to use it Via the USB power cord at the same time as it's being charged, great little item and affordable too. Hop this helps..
SOURCE: how do i hookup my apple ipod to my bose wave music system?
you need a 3.5mm male TRS to stereo male RCA plugs. the TRS plug goes in the IPod headphone jack. the RCAs will plug into the line in jacks on the rear of the Wave. good luck.
SOURCE: adding turntable to bose music wave system
Hiya, sad to say it wont work even with the correct plugs. If you really need/want to get it going, you will need a RIIA pre amp to use to convert the turntable levels to an acceptable level for the bose. Once you have that, then get the correct matching plugs for the bose (sames guys that supply the preamp should be able to help). Suggest a google search in your area "RIIA PREAMP" and see who supplys.
Best of luck
SOURCE: I have an older Bose Wave radio without a CD. Can
If it has another input then yes if not you will have to get a A/b switch.
SOURCE: what type of battery goes in the remote for a BOSE
We have a Bose Acoustic Wave Audio System II, and our remote uses nickel metal-hydride batteries CR2032.
SOURCE: how to connect my Bose Wave System to two outdoors Bose speakers?
It won't connect to externa l speakers directly but you could take the RCA output to an amplifier that drives them.
