Error code 11-1113 on a Samsung printer indicates a communication error between the printer and the computer. Here are some possible solutions you can try to resolve the issue:
If none of these solutions work, you may need to contact Samsung support for further assistance. They may be able to help you diagnose the issue and provide additional solutions.
Yes
Try download Samsung universal printer driver 2 or 3.
SOURCE: CLP-510 SPL-C Error message
SPL stands for "Samsung Printer Language". You are using an USB cable that is either too long (above 6 ft.) or too thin (cheap cables).
The reason why the test page prints is because it is a very simple and small page (thinking on kbyte terms). But larger streams of data do not arrive correctly due to attenuation and the error page prints instead.
If it is absolutely necessary to connect beyong 6 ft, you need either a good quality USB cable (try the Belkin brand found at OfficeMax), or connect using a parallel cable.
SOURCE: SPL-C ERROR - Including Corrupted Data
its nothing the dll file has got corrupted call to the toll free no and ask for resolution....
SOURCE: SPL-C ERROR with Samsung CLX-3160 FN when printing from iMac
This can be fixed by stretching out a solenoid spring on the power cord
side of the printer. The solenoid acts as a clutch to stop the spinning
developer actuator at the right spot. The picture below is from a Samsung CLP-300 but these both use the same Imaging Unit so this should work. It's just a little more involved taking off the top scanner / buttonpad off the CLX-3160.
Open up the right side (power cord side) of the printer (take off top
cover, then take off side cover). Then, find a solenoid (little metal
square) that touches the white plastic vertical spur gear. Take the
spring off the solenoid. Now, put the spring back on - only this time
you will attach one anchor point to the middle of the spring as to
pre-stretch the spring for more tension.
The problem is that the spring gets weak over time / the cogs round out
over time and the solenoid finger is overcome by the spinning cogs, and
resulting in selecting the wrong developer.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
SOURCE: printer stops printing after first
Try disconnecting your printer from your pc and then uninstalling the drivers for it in your control panel. Go to the manufacturers website (Samsung) and click on the drivers and sofware area to download a new copy of the files necessary to run it.
After installing, reconnect your printer to your pc and try printing a test page to see if this has corrected the error.
